Pistons
Old Oct 5, 2003 | 08:01 PM
badazzcamaro97's Avatar
Pistons
I am trying to figure out which would be the correct JE piston to use on my 97 Lt1. I would like to have 9.5:1 compression.
Old Oct 5, 2003 | 08:14 PM
Josh-'04 GTO's Avatar
Jegs has these JE forged pistons listed. Part number 532-170817 is an inverted dome that will come in around 9.2:1. That will be the closest off the shelf piston for your stated goal of 9.5. In addition, if you have your heads resurfaced, or run a thinner head gasket, that will bump your compression closer to 9.5.
Old Oct 6, 2003 | 07:45 PM
I appreciate it that sounds like what i was looking for.
Z Power
Sep 19, 2015 11:19 PM
DelSoto
Sep 19, 2015 05:31 AM
95craz28
11
Sep 12, 2015 07:47 AM
gonzo275rltw
Sep 5, 2015 06:26 PM
gonzo275rltw
Sep 5, 2015 06:24 PM
