piston slap
Old Nov 26, 2010 | 03:20 PM
mikeyyoungful's Avatar
piston slap
weather has changed and is much cooler.just changed oil synthetic,but i am now getting piston slap.what should i do.
Old Nov 26, 2010 | 03:29 PM
Re: piston slap
Common on the LT1.... mine had it right from the factory. Lasted about 2 minutes on a cold start, went away as the engine warmed up, and never caused a problem.
Old Nov 26, 2010 | 07:31 PM
lt1-xjs's Avatar
Re: piston slap
No problem here, I've heard it for almost 10 years.
Old Nov 27, 2010 | 04:44 PM
Wild Willy's Avatar
Re: piston slap
Just take it easy for the first couple minutes until the parts and oil warm up-
Old Nov 28, 2010 | 12:25 AM
henryz28's Avatar
Re: piston slap
I thought the ls1 had this problem not so much lt1s. I guess I am one of the lucky ones. I also get 80psi of oil pressure with 5/30 on start up and when driving down the road; I always thought that was a lot of psi for a stock oil pump. But yes if you have piston slap just be sure to warm the motor before you drive hard; I would idle until it stops. I have a buddy that has this on his ls1 I always tell him he needs a lt1
Z Power
Sep 19, 2015 11:19 PM
DelSoto
Sep 19, 2015 05:31 AM
95craz28
11
Sep 12, 2015 07:47 AM
gonzo275rltw
Sep 5, 2015 06:26 PM
gonzo275rltw
Sep 5, 2015 06:24 PM
