Piston cc's after milling a 3cc dome?
Old Oct 17, 2013 | 10:45 AM
bombebomb's Avatar
I currently have these installed in a running lt1, however the domes were milled off before they were installed. I'm having trouble reassuring myself how to calculate piston cc now since the 3cc dome is gone. I don't even know if you can calculate it with the information I have on hand...
So, anyone have an idea on the current cc's since the dome is gone? I looked at other similar pistons and they were 5cc with two valve reliefs and flat tops however, again I have no idea if you can even compare them that way.
Hope someone can help, with the little information I have on hand.
Thanks!
http://www.summitracing.com/parts/je...09-8/overview/
Brand:JE Pistons
Manufacturer's Part Number:232509-8
Part Type:Pistons
Product Line:JE Pistons Small Block Nitrous Series Dome Top Pistons
Summit Racing Part Number:JEP-232509-8
Bore (in):4.030 in.
Bore (mm):102.362mm
Piston Styleome, with two valve reliefs
Piston Material:Forged aluminum
Compression Distance (in):1.125 in.
Piston Head Volume (cc):-3.00cc
Wrist Pin Style:Press-fit or floating
Pin Diameter (in):0.927 in.
Piston Ring Thickness:1/16 in. x 1/16 in. x 3/16 in.
Quantity:Sold as a set of 8.
Notes:Oil rail support included. Solid dome design.
Old Oct 17, 2013 | 01:18 PM
Re: Piston cc's after milling a 3cc dome?
If the piston started with a 3cc dome, and you milled them flat (no valve reliefs), the cc's would be "0". If they have valve reliefs, you have to cc them to determine the volume.
A dome is minus cc's, a valve relief or dish is plus cc's and a flat top is 0.
Old Oct 18, 2013 | 02:26 PM
bombebomb's Avatar
Thank you, I called the manufacturer, and had another opinion. It came to out to 5cc's after the valve reliefs (relatively large).
Thank you again
Old Oct 18, 2013 | 03:47 PM
Thank you again
I don't know why the manufacturer would have a different opinion. I clearly stated that if they were truly flat and had no valve reliefs they would be 0. If you cut valve reliefs after removing the dome, I don't know how the manufacturer would know they are 5cc.
Old Oct 18, 2013 | 08:29 PM
bombebomb's Avatar
No difference in opinion, just different information. You stated that if it was a true flat top, then it would be 0 (which is true). The piston I have (in link) is a domed piston with two valve reliefs.
Again, thank you for chiming in
Z Power
Sep 19, 2015 11:19 PM
DelSoto
Sep 19, 2015 05:31 AM
95craz28
11
Sep 12, 2015 07:47 AM
gonzo275rltw
Sep 5, 2015 06:26 PM
gonzo275rltw
Sep 5, 2015 06:24 PM
