94 impala ss motor in 94 z28
Old Oct 17, 2013 | 07:55 PM
jcroff's Avatar
bought a 94 z28 and have a spare 94 impala motor laying around can I put the impala motor in the Camaro....I no the timing cover and opti is different but as long as I get the impala opti would that work? also there is not an oil cooler but wouldlike to add one I have the oil adapter from the impala motor I plan on just buying impala oil cooler lines and modifying them to an external cooler... does anyone see anything wrong with these plans or is there anything else that is different between Camaro vs impala motor I will have to address?
Old Oct 17, 2013 | 08:26 PM
parkers Z28's Avatar
Re: 94 impala ss motor in 94 z28
I think the B-body has a different cam?? and cast iron heads ?? Your going to lose a few hp
I could be wrong
Old Oct 17, 2013 | 08:59 PM
97WS6SCharged's Avatar
Might want to check the numbers and make sure it's an LT1 and not an L99.
The oil coolers circulate water from the radiator around the adapter above the filter, they don't move oil. I wouldn't run one of the street personally. Just another source of weight and potential leaks.
Old Oct 18, 2013 | 11:19 AM
John95z28's Avatar
Yup, the impala has cast heads that flow better stock by 10%, but the aluminum ones are portable, lighter, and disperse heat better.
The cam delivers about 20 more torque(dyno) on the low end to the wheels, although about 20 less hp. However the numbers were rated with 87 octane, so that isn't bad seeing as your 0-60 may go up depending on your rear end gears.
Old Oct 18, 2013 | 02:36 PM
KW Baraka's Avatar
The Impala engine (if it is an Impala engine) is identical to a Camaro engine of the same year.....including Opti and timing cover.
As for oil cooler components.....use what's on your Camaro....NOT....what's on or should be on an Impala. If the oil lines are spec'ed for the Impala, they likely will not work on your Camaro without significant modification.
Impala heads are cast iron.....so you might want to use the aluminum heads.....which are about 50-60 pounds lighter.
The Impala cam is a 'torquer' cam....not a HP cam. If you want low RPM torque.....use the SS cam. Otherwise, use your Camaro cam.....or an aftermarket cam.
The water pumps are vehicle specific.....so be sure to use a F-body pump!
Use all accessory brackets/belts/etc from the Camaro.....the Impala set-up won't do for you.
Originally Posted by 97WS6SCharged
Might want to check the numbers and make sure it's an LT1 and not an L99........
Easiest way to ensure that the engine is in fact a LT1 (versus a L98) engine.....look for the numbers "327" casted on the passenger side of the block.
Good luck!
KW
Old Oct 18, 2013 | 03:44 PM
Not identical.
The Impala/SS got the vented Opti in 1994. The F-Body didn't get it until 1995. So the timing cover, cam sprocket, cam dowel pin and the Opti would be different.
Old Oct 19, 2013 | 03:01 PM
jcroff's Avatar
All Good Points... Im Basically Frakensteining A Motor Together Short Block From Impala With Hot Cam Kit And Timing Cover And Opti From Impala....Heads From Camaro And What Not. I Bought The Camaro And Motor Was Locked Up So I Rebuilt The Old Motor I Took Out Of My Impala When I Swapped The 383 In.
So Putting An After Market Oil Cooler Is Not A Good Idea? I Should Just Put The Oil Filter Adapter On?
Old Oct 19, 2013 | 03:21 PM
Don't worry about an oil cooler. Just use a regular filter adapter.
Old Oct 19, 2013 | 06:27 PM
jcroff's Avatar
excellent thanks for the replies.......
HectorM52
Jul 30, 2017 11:46 AM
Jan 5, 2015 07:14 PM
NewsBot
Dec 28, 2014 06:20 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
