piggyback pulley VS ASP replacement pulley on LT1
Old Oct 24, 2004 | 08:31 PM
  #16
MarkyMark's Avatar
Re: piggyback pulley VS ASP replacement pulley on LT1
dmoor they tell you on the site what belts to use...if you have the ac delete pulley then you will pretty much just have to measure it and try and find a belt that will fit.
Old Oct 24, 2004 | 09:37 PM
  #17
Spinner's Avatar
I also have a/c delete as well as the pully, that may be why i needed a 10mm shorter belt then what they recommended for the pully
Old Oct 24, 2004 | 10:17 PM
  #18
dmoor88's Avatar
oh well that makes sense.
Old Oct 25, 2004 | 12:10 AM
  #19
rpm4lalo's Avatar
Those of you with the ASP crank pully. How do you take it off. When I went to install a cam, I had to place a piece of metal stock behind it and slam on that with my air hammer to get the damn thing off???
Old Oct 25, 2004 | 04:22 AM
  #20
MarkyMark's Avatar
use a 3 jaw puller........my stock one came off really easy with a puller and I imagine that the asp one would come off just as easily. You will have to remove the passenger side fan to make room, but that is no biggie.
HectorM52
Jun 23, 2016 08:42 PM
SpeedJunkee
Jan 27, 2015 10:02 PM
1LEThumper
Jul 14, 2003 12:45 PM
