Cheapest valve train setup for CC306!!!!
Old Oct 22, 2004 | 12:33 PM
BlackLT1_TX's Avatar
Right now I have:
ARP hardend rocker studs
Lunati Springs (seat load, hght1.750 load108)(open load, hght1.250 load339)(coil bind 1.060)(max lift .630)(rate 462). These going to be okay?
Stock Lifters
Hardend pushrods
GMPP 1.6 R/R's.
Please someone examine this setup and turn it into a competent CC306 valvetrain.
-James
Old Oct 22, 2004 | 01:06 PM
madwolf's Avatar
Re: Cheapest valve train setup for CC306!!!!
All of that will support a 306, but I'd get some new lifters and new pushrods if those are stock.
Old Oct 22, 2004 | 01:14 PM
JordonMusser's Avatar
West South Central Moderator / Special Guest
crane 10308 spring set. stock rockers, stock push rods, stock lifters, etc.
Old Oct 22, 2004 | 02:02 PM
Jordon, I believe the guy I bought these from said that he bought them from you. Did you have a set of these springs at any point? The guy had never used them, did you?
Old Oct 22, 2004 | 02:41 PM
dmoor88's Avatar
do those lunati springs fit stock seats or do the heads have to be machined?
Old Oct 23, 2004 | 11:18 AM
BlueCamaroZ28's Avatar
I've been looking at Summit Racing catalog for springs kit (springs, retainer & locks) to fit stock heads without machining and to support cc306:
I have found:
CRN-10309-1
CRN-10308-1
I know Comp Cams springs 986 & 987 (double springs) need machining and they don't sell them as a kit. I don't want to end up with wrong retainer and locks that don't fit with the springs.
Anybody have part#s for Comp Cams springs, retainers & lock that will do the job for cc306 with now head machining to fit the springs.
Old Oct 23, 2004 | 03:06 PM
dmoor88's Avatar
you can always check out the EX-612 spring set from cmotorsports.
good to .600" lift, single coil, fit stock seats.
Old Oct 24, 2004 | 02:09 PM
MyGreenBabyZ's Avatar
The 10308's say that they dont come with a damper spring between the springs, and what are their maximum lift?
Is a damper spring necessary?
will new stock lifters be up to the task of these springs, .560 lift, and about 6500 RPM?
Old Oct 24, 2004 | 02:33 PM
dmoor88's Avatar
yea stock replacement lifters should work just fine. thats what im going with when my 227/233 .560/.569 comes in
Old Oct 25, 2004 | 06:29 AM
It's a double spring. The 10309 is a single spring and uses a damper, but, it doesn't come with locks.
Old Oct 25, 2004 | 06:41 AM
is it necessary to have a damper? or will those springs work fine for a street applications?
thanks
AdsoYo
May 2, 2018 03:21 AM
LimitedEd1LE
May 18, 2015 01:24 PM
carl.froehlich
Mar 13, 2015 12:38 AM
Jazsun
Dec 29, 2014 12:14 PM
