Picture of Passenger side of block
Old May 27, 2008 | 02:24 PM
carolinacasper's Avatar
Does anyone have a picture of the Passenger side of the block? I've looked at shoebox's website and didn't find a big enough picture.
I have a big coolant leak either at the knock sensor, heater hose, or cylinder head steam pipe. I need to know what else is down there.
Hopefully the head gasket isn't blown.
Old May 27, 2008 | 02:28 PM
ChevalierSS's Avatar
freeze plugs are about the only thing you didn't mention.
Old May 27, 2008 | 02:58 PM
The steam pipe does not go down on the side of the block. Sounds like you need to get under there and look real close.
Old May 27, 2008 | 04:52 PM
SnakeOiler's Avatar
where at does it puddle under the engine?
Old May 28, 2008 | 01:00 PM
The Coolant drips on the exhaust which steams like no tomorrow and puddles under the starter motor.
The problem started Monday night, and in 5 minutes I had lost approximately 2 quarts of coolant.
I'm not sure where its coming from even when I look from underneath. Everything on that back corner of the block has been sprayed with coolant. I went to buy a mirror on a stick last night, but ended up coming back empty handed.
My best guess is the steam pipe spraying. But I'll post back here when I get a hold of a mirror on a stick.
Old May 28, 2008 | 01:11 PM
30AnniversaryZ28's Avatar
These are the best of mine I could find.
hot_red_z28's Avatar
Sounds like a possible head gasket leak too... Hopefully it is the steam pipe at the back of the heads, but it could be a bit worse... That's a lot of fluid to lose out of a simple leaky steam pipe...
Old May 28, 2008 | 01:25 PM
SnakeOiler's Avatar
Originally Posted by hot_red_z28
... Hopefully it is the steam pipe at the back of the heads...
it's either that or the head gasket
I guess there is a longshot of the block being cracked, also.
Old May 28, 2008 | 02:09 PM
blue 79 Z/28's Avatar
what about the heater hoses that run along the pass. side frame rails to the heater core? that seems like it could be a possibility.
Old May 28, 2008 | 08:00 PM
SnakeOiler's Avatar
now that I read it again. . . that is a lot of coolant. High possibility of a busted hose. Those are definitely tough to check back there.
Old May 28, 2008 | 10:17 PM
Probably a heater hose.
Old May 29, 2008 | 03:50 AM
Don 97 SS's Avatar
Gads, at that rate it has to be a heater hose.
Old May 30, 2008 | 08:44 AM
Started the LT1 again last night and found the leak. :-)
I replaced the heater hoses last year, but ended up using plain hoses that I wrapped in foil and zip tied which worked very well on the areas I wrapped.
However, part of the unwrapped hoses is touching the EGR tube and burnt through. **Home-Simpson DOUGH!!!!!**
I should have this fixed on Saturday. Anyways, thanks for the suggestions.
DirtyDaveW
Mar 15, 2015 07:01 PM
alex5366
Feb 17, 2015 10:43 PM
Jul 4, 2005 05:00 PM
