Cross Threaded spark plug threads?
I went to change my plugs today to tr55s and went through all of them except for the last one in literally 30 min. When i got to the passengers side, on the frontmost cylinder, i started threading the plug and i noticed after a turn or two it got hard to turn. So i torqued it a bit but then backed off when it didnt get any easier. What should i do? Thread chaser? Thread repair kit? Of should i just torque it in as tight as i can? If i do some sort of thread repair, how do i ensure that i dont get shavings in the cylinder? Thanks guys
first off you should always start your plugs by hand and get at least 2 full turns on the plug before you put a wrench to it. That being said you need a spark plug thread chaser to clean and realign the threads. do a little at a time with grease on the chaser and clean off chaser every couple of threads until it starts going in easy.
You shouldn't have any problems if you thread it in straight. If you booger it to the point that you can't get a plug to tighten sufficeintly, you may have to resort to a helicoil. JMHO
Darth_tsunami
V6 Tech
Sep 18, 2015 01:57 AM
