Pics of LT1 Jet-Hot LTs & k-member area
Originally posted by LWillmann
Hey BitCypher, you have a chance to make those measurements for me yet? I sure could use them.
Later this evening when I get home I'll try to lay a straight-edge across both jack-pads and measure the "drop" of both collectors from that point. I think this is what you're after anyway. If it's not, it'll have to wait until Wednesday.
That's basically what I'm after, just a measurement of the drop from the jackpad to the bottom of the collector.
Then I can measure from my jack pad to the floor, and that will tell me roughly the clearance for my headers...
It will work even with your car on jackstands.
Driver-side, floor-pan to bottom of collector: 4 3/4"
Pass-side, heat-shielding to bottom of collector (see pic): 6 3/8"
Here's the pics for proof:
http://www.classicgaming.com/vcoleco...s/img_1456.jpg (Taken from floor-pan driver-side)
http://www.classicgaming.com/vcoleco...s/img_1460.jpg (Taken from level, front-most position on heat shielding)
Thanks a TON here man!
With your measurements of that and the ride height you did a while back for me, it's been a big help!
Now I have to see if I'm going to have ground clearance without raising the front end some...
oldschool
Feb 9, 2016 09:21 PM
squarehead
Nov 21, 2014 08:02 PM
