performance
Old Mar 18, 2012 | 06:46 PM
Timmae's Avatar
performance
I have 94 z28 automatic. I'm curious. What are some good upgrades to put on my car. I have an elite cherry bomb exhaust with some upgraded headers. What else wld b some good add ons??
Old Mar 18, 2012 | 07:27 PM
97z28k&N's Avatar
Re: performance
Bolt ons are the easiest place to start. Add a performance (cold air) intake next.
Old Mar 18, 2012 | 07:57 PM
dennis5374's Avatar
Re: performance
What kind of headers? What size exhaust? More details would be better honestly. Are they shorties mid length or long tubes? Do you have an after market y-pipe? What do you plan too do in the future to the car? All of these things makes a difference as to what you should do but a cold air intake is definitely next on the list.
Old Mar 18, 2012 | 08:00 PM
mrmint69's Avatar
Re: performance
Are you looking for handling or more horse power? Also what is you budget? You can go big and do heads and a cam or there are several free and low cost mods.
Old Mar 21, 2012 | 09:53 AM
GRIDERMAN87's Avatar
Re: performance
Stall converter...cold air.....3.73's and itl be pretty solid
Old Mar 22, 2012 | 01:16 AM
SDD929's Avatar
Re: performance
I have a 1994 Z28 manual 6 speed. I also want to get more HP would I have to switch to LT4 heads, throttle body, and change cam? I'm new to this game
Old Mar 22, 2012 | 05:27 AM
Re: performance
Welcome to CamaroZ28.com ! ! !
Best thing to do would be to start a new thread of your own, so that it doesn't confuse the responses to "Timmae".
There's a lot of help here, and the more info you provide about any current modifications to your car, mileage, etc. the easier it would be to help you.
LT4 heads? No. You can make close to 500HP at the flywheel with ported stock heads and the right cam. Probably a good idea to read through some threads, see what others with fast cars have done, and then start asking questions in a new thread.
Old Mar 22, 2012 | 11:44 AM
raroz28's Avatar
Re: performance
If you are happy with the sound of your exhaust, I would put on a cold air intake.
Don't buy new, you can get them used all day for around $80 on here.
Old Mar 22, 2012 | 01:41 PM
Joe Bellman's Avatar
Re: performance
If your '94 has original suspension components, buy the polyurethane bushing kit to replace most of the rubber pieces. They are all junk by now. New shocks would be good too. It will handle better than new. Find some used wheels from a Z06 and put on there. Fatter, stickier tires makes the curves more fun.
No point in making more power if you can't control it.
Old Mar 23, 2012 | 08:59 PM
6772owner's Avatar
Re: performance
I agree, I would do suspension upgrades, sub frame connectors, wheels/tires before any horsepower mods. I would also consider a front brake upgrade, I am looking into doing either LS1 brakes or Corvette stuff myself.
Old Mar 24, 2012 | 08:02 AM
raroz28's Avatar
Re: performance
I actually forgot about all that stuff. First thing I did to my car was BMR LCA's, relocation brackets, Adjustable panhard rod.
Definitely a must, and not at all expensive.
Old Mar 24, 2012 | 09:11 AM
Re: performance
I think this is getting a little sidetracked. Yes, its important to upgrade all components to match increases in engine power. But EXACTLY what needs to be done is subject to how you use the vehicle. The upgrades for a road car will be different from those for a 1/4-mile car.
As an example, the stock brakes are decent. Yes, you can upgrade them. But my stock brakes (still has the original front pads) will pull the car down from 130 MPH traps speeds with no problems at all. If you want to get down to basics, I'd change every fluid in the car, including the brake fluid. I doubt it's been changed since the car was new. I actually had the parts for a Baer front brake upgrade, but decided to sell them, because they would have made it impossible to fit 15" Pro-Stars with skinnies in the front.
Old Mar 24, 2012 | 03:45 PM
englundjd's Avatar
Re: performance
dont forget the little free mods and a tune up lol
Aug 24, 2015 06:41 AM
karpetcm
Aug 14, 2015 03:02 PM
RallyRed701/2
Jul 27, 2015 02:55 PM
RX Speed Works
Jul 24, 2015 02:25 PM
Catmaigne
Jul 14, 2015 05:17 PM
