big cam and stock heads questions
Old Mar 22, 2012 | 09:30 PM
dennis5374's Avatar
Pretty straight forward question here. Will a large can like the cc306 or gm847 with stock heads raise the r.p.m at which you make peak power? The reason i ask is because i had a xfi280 c.a.m on a set of non ported castings that was making peak power at 58-5900 r.p.m.s. is it because the heads don't have the volume or velocity to flow enough to pull power to 6500+?
Old Mar 22, 2012 | 09:33 PM
RamAir95TA's Avatar
Re: big cam and stock heads questions
I made the mistake of running an XE 236/242 on stock heads and boy was it a disaster. The car made no power down low and peetered out by 6200, tops.
You have answered your own question. If the heads can't support the air/fuel flow produced by the new cam events of course it won't make power in the higher RPMs.
Old Mar 23, 2012 | 03:53 PM
Mystery Bird's Avatar
I had the xfi280 with ported heads though and it pulled hard all the way to about 6600, ran a best of 11.63 @116 with it.
Old Mar 24, 2012 | 05:20 PM
shawngamblez28's Avatar
im running a comp cam 525/525 236/242 on stock heads with aftermarket valve springs an 1.6 full roller rockers an ported intake.been that way for 2 years.best on motor was 12.30 an a 125 shot was 11.55.still runs great an daily driven.
Old Mar 24, 2012 | 05:35 PM
dennis5374's Avatar
The question was based on my current setup with nitrous. My power always fell flat at 5800. The heads were milled 30 thou and the block was zero decked. I can't seem to track down the dyno graphs but i know even with the Nos it still fell flat right around 5800-5900. Now that i have a set of le3 heads with the 205cc runners and still a true 54cc combustion chamber I was assuming it would have slightly less compression but be able to pull well past 6k with or without the Nos. My boosted plans are on hold as I ran into an issue money wise too build the short block but my intentions were to use my le3 heads with a custom ground c.a.m setup for boost and nitrous in the future.
Old Mar 24, 2012 | 05:39 PM
dennis5374's Avatar
Did it make power to 6600 on a dyno or feel like it was still pulling hard up top? I know a dyno is a tuning tool but i still should be pulling into the 6k+ range especially with the spray. I made 503 ft lbs with a 150 shot at 3800. Only made 389rwhp @5800 with a 150 shot which to me seems extremely low
Killer94z
Jan 13, 2015 12:06 PM
birdblack
Dec 30, 2014 06:59 PM
jmzlt1
Mar 13, 2003 07:26 AM
MJ_Z28
Aug 8, 2002 09:07 PM
Brian-94TA
Jul 31, 2002 02:52 PM
