People w/ Solid Roller setups>>>>>>
Old Jul 25, 2008 | 02:49 PM
  #61
DirtyDaveW's Avatar
Poll the other SR faithful here for a recommendation on a forced lubrication/self oiling SR Lifter. I bought a used SR setup that used the traditional SBC Crane SR with the horizontal bar. In all the build up when I was asking all the questions about it, not one person mentioned NOT using these lifters. I only got to drive it about 8 months before one of the lifters came apart and trashed the 383 stroker I'd waited 2 years to get put together. Once I told everyone that it had died, THEN they were full of recommendations and information about what I should have done. Lol... I'd never even heard of such lifters. It's all okay now though. I have a new motor and, even though I loved the power of the Solid roller, I'm even more in love with my current setup.
Originally Posted by The Engineer
I'm definitely going to an SR next season (I think my current HR on a 113 LSA is really holding my car back). I’ll probably go with a Comp custom grind on a small base-circle with something along these lines; 108 LSA, Int/Ext duration around 250s/260s and lift at the valves in the .630” to .650” range.
I haven’t selected all the valve-train components yet, but when Lloyd Elliot reworks my AFR-195s during the off-season, I’ll probably go with new 2.050” intakes and the .100” longer valve stems. I have Jesel Sportsman shaft rockers and they came with the .100” spacers. Also, I haven’t decided which SR lifters to use.
WD
Old Jul 27, 2008 | 12:01 PM
  #62
flyinZ's Avatar
What kind of oil psi, does everybody run @ idle?
I know it might have been mentioned, but what can you do mechanically, to help oiling @ idle? Other than raising the idle up..IMO, thats a bandaid.
Old Jul 27, 2008 | 01:30 PM
  #63
jakesz28's Avatar
Manton 3/8 pushrods with a .120 wall here
Manley 221442-16 springs
T&D shaft mounts (+.250 stand height)
Cam Motions SR
Valves were installed at 2.100"
Old Jul 27, 2008 | 02:27 PM
  #64
DirtyDaveW's Avatar
Here's the thread from my solid roller. Within it you'll find references to the machining you can do to either the lifter or the lifter bores, plus the pressure oiling lifters and importantly, *what* kind of oil (not just synth. That's not enough).
https://www.camaroz28.com/forums/sho...d.php?t=555607
Old Jul 27, 2008 | 05:12 PM
  #65
SS RRR's Avatar
I use a standard flow oil pump, idle at 1000 or 1100 rpm and have 17psi, but increases dramatically once rpm increases (ie ~40psi @ 2000rpm). This is with oil restricting pushrods, however I did not notice an increase in pressure at idle w/ the OR pushrods over standard ones.
Just for reference I am using Isky Red Zones. Naturally when I first bought them Isky didn't bother informing me that there would be a decrease in oil pressure due to the extra oiling holes for the roller bearing.
You can use oil restrictors which go into the block or use a high pressure oil pump as long as you have an acommodating oil pan.
RUENUF
Mar 13, 2016 03:37 PM
GusarskiSS
Exhaust System
Sep 2, 2015 03:51 PM
FryedClutch
Sep 1, 2015 08:24 AM
Slayer
Aug 17, 2015 03:55 PM
