People w/ Solid Roller setups>>>>>>
Old Jan 14, 2007 | 09:43 AM
  #16
chrism400's Avatar
Comp Xtreme solid street roller 254/260 .622/.628 lashed at .014/.016, used K-motion 900's, chrome moly retainers and locks, 7/16 studs, Howard solid rollers (239.00) with .010 oil slot cuts, clearanced Blue Racer 1.6 rockers, and alot of borrowed time.
Old Jan 14, 2007 | 12:18 PM
  #17
firetird's Avatar
cam motions 250/256 .636/.616 on 112 with scorpion 1.6 rr's. k-motion k1100 springs (I think thats the part number), endure-x lifters, comp cams pushrods, le heads, 2.02 1.56 manley valves.
Old Jan 15, 2007 | 07:57 PM
  #18
DirtyDaveW's Avatar
Cam:
Brand: Cam Motions
.......: Dur@ .050 = 242/252
.......: Lift .606/.606
.......: LSA 108.9
Lifters:
.......: Brand: Crane
Roller Rockers:
.......: Brand CompCams
.......: Type = 7/16" studed 1.6 Pro Mags
Springs:
..........: Brand Cam Motions
..........: Diameter 1.550
..........: Seat pressure 200 lbs.
..........: Open Pressure 500 lbs.
Heads:
........: Ported (By Will Garza @ Houston,TX) LT1 Castings
........: Valve size 2.00/1.55 stainless Ferrerra
........: Flows 275/195 I/E
Pushrods:
........: Brand TFS
........: 7.500 is stock length. After measuring with adjustable pushrod kit(Comp Cams CCA-7705) and Manley pushrod length checker (Manley MAN-42132) I found that the length measured was 7.850. This was in the middle of the TFS offerings of 7.800 and 7.900 so I opted for the 7.9's.
Still needing stud girdle and tall valve covers that will clear the alternator. Anyone have a reference/experience with the tall LT1 valve covers?
Old Jan 16, 2007 | 12:56 PM
  #19
MEAN LT1's Avatar
The canton aluminum valvecovers should clear the stud girdle.
Old Jan 16, 2007 | 01:04 PM
  #20
MEAN LT1's Avatar
So whats everybody getting out of there SR setups? HP?,et/trap?
Old Jan 16, 2007 | 02:47 PM
  #21
DirtyDaveW's Avatar
Obviously, mines not together yet but the guy from whom I purchased my solid roller said he got 457 rwhp out of it with a similar config. That being;
383 LT1, stock but ported LT1 castings(his was a home port job, mine a pro), 11:1 CR, stock 48mm TB, Hooker LT.
Old Jan 17, 2007 | 08:21 AM
  #22
MEAN LT1's Avatar
Anybody else?
Old Jan 18, 2007 | 09:36 AM
  #23
526 SS 96's Avatar
I have a solid roller & cnc lt1 heads from AI. The usual SR stuff: TI retainers, morel lifters, stud girdle, etc. I would have ran shaft mounts if I didn’t already have the comp promag rockers. They work, but I may upgrade to jesels this spring. I have the moroso centerbolt tall valve covers, no clearance issues. The only thing you have to do is get a alternator relocation bracket. It puts the alternator where the air pump used to go.
I got 480 rwhp & 419 rwtq out of my 355.
The vid has still pictures of my valve covers and valve train.
http://videos.streetfire.net/search/...7c00207164.htm
The SR is bad ***, I don't thnink I will ever go HR on another performance engine again.
Old Jan 18, 2007 | 09:39 AM
  #24
MEAN LT1's Avatar
I remember your setup, very nice. You ever get that rear end taken care of?
Old Jan 18, 2007 | 09:58 AM
  #25
526 SS 96's Avatar
Thanks! Yes I did. It's getting ready for spring.
Old Jan 19, 2007 | 08:30 PM
  #26
DirtyDaveW's Avatar
Originally Posted by Injuneer
CC cam, Crower Cutaway Severe-Duty lifters, CC 5/16" Hi-Tech pushrods, CC 1.6-I/1.55-E Pro-Magnum rockers, Manley guideplates, PSI valve springs, Manley titanium retainers.
Are your valves still stock length stems? If so, what length pushrod did you go with?
Old Jan 19, 2007 | 08:35 PM
  #27
Projectz28's Avatar
Moderator
I have no idea what mine will make when its running, but I will be dissapointed if it doesnt make at least 450rwhp... hoping more towards 500rwhp.
Old Jan 19, 2007 | 09:13 PM
  #28
MEAN LT1's Avatar
Whos working your heads?
Old Jan 20, 2007 | 05:39 AM
  #29
Projectz28's Avatar
Moderator
its way back on the first page but the heads were done by TEA. 220cc TFS LT1 head. 63cc chambers, 2.08/1.60 valves, flowed 317 @.700. I'm running a domed piston for 12.4 static compression, and a cam motion SR. 263/270 .686/.674 lift. dynamic comp comes in right at 8.9-9.0 (cant remember exactly, the numbers are starting to just all blurr together ) Should make for a really nasty idle in a 355 but its not a street car anymore.
My original goal was to build a motor with 550 fwhp. working with my machinist we ended up shooting a little long I think. I went overboard in a few areas so that even if I fell short I will have a reasonable chance of hitting my goal. I think this motor is capable of 600fwhp. Its got alot of good stuff on it from the Canton pan all the way up to the LT4 intake. Heck I even indexed and numbered the plugs...
Old Jan 20, 2007 | 09:36 AM
  #30
MEAN LT1's Avatar
Anybody have any problems with low idle oil pressure?. I know this was a problem with these setups in the past. Im just wondering if this problems is still out there.
