PCV valve question, please help
Old Aug 14, 2003 | 07:27 PM
ONELOUDKAR's Avatar
Is there suppose to be a hose connected here.... driver's side in the middle of the intake.... and should it go the the front of the intake under the throttle body? On the side of the intake in the middle, all I have there is a black rubber groument with a hole in it. I think this is suppose to be my PCV isn't it?
please help........
-Mike
Old Aug 14, 2003 | 07:31 PM
AsianSensation's Avatar
It appears you are missing a few parts.
This is what it suppose to look like.
Old Aug 14, 2003 | 07:36 PM
ONELOUDKAR's Avatar
what would happen if i didnt have it? how would my car react?
would it have low or high rpm at idle?
Old Aug 14, 2003 | 07:52 PM
ONELOUDKAR's Avatar
anyone??????????????
Old Aug 14, 2003 | 08:00 PM
If you don't have it:
1. It can't draw out the crankcase vapors into the intake manifold bacuse it uses the manifold vacuum to draw it out.
2. You won't draw the blowby to the combustion chamber.
3. When the engine is off or backfires, the PVC closes so it won't let blowby back into the intake manifold. It could ignite the fuel vapors in the intake manifold.
That's all I can remember. I'm sure there's more to it. Maybe somebody else can add to it.
You can clearly see it how it's routed from my intake manifold.
Old Aug 14, 2003 | 08:30 PM
ONELOUDKAR's Avatar
well, it seems to me that i do not have a pcv valve on my car then. would it throw any codes if it isnt there?
Old Aug 14, 2003 | 08:56 PM
You won't likely see any codes. The more curious thing would be if the port under the throttle body is also left open. That would cause a vacuum leak and maybe some idle/driveability problems.
The open hole where the PCV should go should not be left open. It can only help in dirt getting into your engine.
Old Aug 14, 2003 | 09:02 PM
ONELOUDKAR's Avatar
so should i replace it all and fix it? i can hear air coming from down around that area under the throttle body as well. what should i do SHOEBOX?
Old Aug 14, 2003 | 09:54 PM
Get the parts to put it back together.
HectorM52
Jul 30, 2017 11:46 AM
oldschool
Feb 9, 2016 09:21 PM
LT14LIFE
Feb 9, 2015 09:35 PM
Jul 4, 2005 05:00 PM
GA93FORMULA
Jul 24, 2002 11:38 PM
