PCM question?
Old Jan 24, 2008 | 03:33 PM
rexcellent's Avatar
PCM question?
I'm not sure if I'm asking this in the right section or not, but what all is involved to run a 94-95 PCM in place of a 93 ECM?
Is the only thing you have to do is tune out the MAF sensor?
What else would there be? Does anyone know if any of the tuning places sell setups like this already, PCMforless, MADZ28, etc?
Old Jan 24, 2008 | 04:04 PM
Or you could add an MAF sensor to your 93.
You would have to rewire the injectors, since your 93 has two wires to fire all the injectors in each bank simulatneously, while the 94 and up has 8 individual wires to fire the injectors in sequence. You would also have to convert to 4-wire heated O2 sensors, since the 94 PCM checks the heater circuits. Then you would have to bypass the PCM connections for the electronic M6 controls, like the skip shift, which your 93 M6 does not have. I think the 93 IAC motor functions differently than the 94+. And someone indicated the 93 has the fuel pump interlocked to the oil pressure, which I can find no evidence of on the 94+ cars. That does not go through the PCM though.
The speedometer is also controlled differently in the 94+ cars, within the PCM.
Old Jan 24, 2008 | 05:50 PM
rexcellent's Avatar
WOW! There is a lot more to it then I thought. Think I will just stick with burning chips rather than going through all of that. Thanks for all the info!
DirtyDaveW
Dec 1, 2016 05:37 PM
94Form
Feb 10, 2015 11:23 PM
Deadbolt24
Jan 19, 2015 01:29 PM
Injuneer
Dec 15, 2014 09:36 AM
dreamer1q
Aug 20, 2002 11:19 AM
