pcm info
Old Apr 9, 2003 | 02:00 PM
snakepit79's Avatar
pcm info
Im looking for info on pcm's the components that make up the pcm. really any info on the pcm you all can find
Old Apr 9, 2003 | 02:33 PM
Rodrigues's Avatar
Re: pcm info
Like what? It just consists of two boards and the brain of the PCM consists of a AN28F512 Intel chip. There are two of them and I can send you the hex files if you want them. If you want to re socket the pcm's chip you will need a 32 pin PLCC style socket as well as solder braid and a thin tipped soldering gun. Some people use a heat gun to remove the chips.. You might want to try the PCM forum
Xiantyl
Jul 21, 2015 05:42 AM
colts0455
Jul 20, 2015 09:52 AM
asilomar244
Jul 12, 2015 05:53 AM
colts0455
Jul 8, 2015 12:21 AM
