Pcm/ Fuel pump problems any experience
Old Nov 26, 2003 | 07:10 PM
firehawk0152's Avatar
After chaning the opti and the coil, I cracked down and took the car to a shop. The car will only start when you jump the fuel relay. Either the PCM is bad or the line is bad. does anyone know how I can check for either of them rather than a trip to the dealer.
Old Nov 26, 2003 | 07:17 PM
Tibbys96Z's Avatar
Isn't that what the ignition control module does? I don't know.
Old Nov 26, 2003 | 07:32 PM
It goes to the ICM first, then it follows to the PCM.
Old Nov 26, 2003 | 08:36 PM
The fuel pump relay has nothing to do with the ICM. Without more details on what was "jumped", there is no way to tell what was done or what was proven bad (maybe just the relay?).
Diagram for the relay and leads to the pcm. If it's not the relay, then check continuity on the wiring.
Scottyboy
Feb 11, 2015 10:28 PM
97Z28Muscle
Feb 6, 2015 10:44 PM
RiverMutant96
Jan 30, 2015 09:21 AM
ANDYZ28
Dec 29, 2014 09:13 PM
