Are PCM Failures Common ??? Car is BAD!!!
Old Jul 22, 2005 | 11:21 AM
BigJustinZ28's Avatar
Unhappy Are PCM Failures Common ??? Car is BAD!!!
my car is running poorly and alot of things that can be checked with a voltmeter guage and vacuum guage arent corresponding with the readings im getting from my scanner. Is it possible the pcm got wet and is going bad ??? Ive gone thru the checklist for the ignition in the service manual and it seems like its leaning towards pcm replacement.
Is pcm failure rare and should I keep looking troubleshooting ??? Its leaning one bank out , richening the other , says the right bank cat is ineffecient , tps cuts out sometimes. My scanner sometimes goes dead and I have to restart it while the car is running. All the problems are getting progressively worse too. Im running out of ideas with this car , its been bad all summer and I havent made any real breakthrus.
I have a few autotap logs if anyone wants to see. Thanks in advance , Justin
edit: oh yeah also forgot , when I went to test the coilds resistance I got 5.5k ohms from all three terminals to the wire output but when I pulled the terminal out the plastic piece came apart so I want to replace the coil since now it kinda sits in there. Should I go with GM or the MSD Single terminal replacement ??? Thanks again
Old Jul 22, 2005 | 11:53 AM
93turbo5oh's Avatar
Re: Are PCM Failures Common ??? Car is BAD!!!
my buddies car had a pcm go bad once. one day it was running 11.80s@118 on motor, the next it was zapping optisparks right and left.
Old Jul 22, 2005 | 01:34 PM
my cars noit so extreme but it is definately down on power , any idea why his went ???
Old Jul 22, 2005 | 02:36 PM
BUBBA's Avatar
Probably your o2s. Doubt that it is your PCM. JMHO
Old Jul 22, 2005 | 02:52 PM
HBHRacing's Avatar
PCM failure is EXTREMELY rare. More often then not it's something else. Never suspect a faulty PCM untill ALL other causes have been explored.
Old Jul 22, 2005 | 10:29 PM
already replaced , didnt make any difference. I didnt think pcms were common problems , just hoping maybe I was onto something. Ill check all the computer wiring connections and see If I can find something faulty. Any Ideas besides that ???
Old Jul 23, 2005 | 12:58 AM
pHEnomIC's Avatar
Umm only way i can think of killing the pcm is getting it soaked with water which is unlikely because it is sealed. You could also kill it electrically giving it too much power or heat. Fuses usually eliminate the excessive power problem and idk how you could overheat it without overheating other things.
Old Jul 23, 2005 | 10:21 PM
I did degrease the motor for the first time ever about a month before the car got bad.
Red Hawk 94
Mar 18, 2019 04:03 PM
Injuneer
Dec 15, 2014 09:36 AM
Ricardo
Nov 29, 2014 10:58 AM
USAirman93
Nov 24, 2014 03:37 PM
Snoman73
Nov 17, 2014 07:22 PM
