PCM code help?
Old May 12, 2005 | 12:17 PM
chevy1963's Avatar
PCM code help?
My friiend is throwing this code? 29 what is it?
I got this online, but i'm not sure what it means
P029 (E029) .............. Transaxle Shift 'B' solenoid problem (1st, 3rd, 4th gear)
Old May 12, 2005 | 12:27 PM
97Z-M6's Avatar
Re: PCM code help?
EAS electrical fault
Old May 12, 2005 | 12:33 PM
chevy1963's Avatar
Re: PCM code help?
Ok, how do you fix that?
Old May 12, 2005 | 12:51 PM
Re: PCM code help?
Please give year, make, model of friend's car.
94-95 f-body:
29 = Secondary Air Injection (AIR) pump circuit
Check the AIR pump fuse under the hood.
Old May 12, 2005 | 12:53 PM
chevy1963's Avatar
Re: PCM code help?
It's 95 z28 convert, Thanks Shoebox
Old May 12, 2005 | 01:05 PM
97Z-M6's Avatar
Re: PCM code help?
94-95 f-body:
WHY DOES DATAMASTER SHOW IT TO BE A eas ELECTRILCAL FUALT. OR IS DATAMASTER JUST VAUGE IN ITS CODES
Old May 13, 2005 | 01:05 PM
Re: PCM code help?
DataMaster is giving you "generic" GM fault descriptions. Shoebox's list has LT1 specific fault descriptions, which makes it a lot easier to understand.
Old May 13, 2005 | 01:28 PM
97Z-M6's Avatar
Re: PCM code help?
thanks
where could i get this list.
Old May 13, 2005 | 01:41 PM
kainZ's Avatar
Re: PCM code help?
Did your remove your AIR system? I read somewhere that the 95 cars can have the system removed, as long as you do leave the (good) fuse intact in the fuse box.
Old May 13, 2005 | 04:24 PM
Re: PCM code help?
Originally Posted by 97Z-M6
thanks
Hmmmm.... almost 3,000 posts, and you don't know about Shoebox's Tech Pages :
http://shbox.com/1/4th_gen_tech1.html
Or more spcifically.....
http://shbox.com/1/Dtcs.htm
There's also one at the end of this:
http://members.aol.com/InjuneerZZ/ScanMast.htm
AlaskaZ28
Jan 1, 2015 12:30 PM
Jul 4, 2005 05:00 PM
91Bird305
Aug 5, 2002 01:39 PM
tbyrne
Jul 2, 2002 05:37 PM
Z28AZ
Jun 14, 2002 04:16 PM
