Passing Emissions
Old Dec 1, 2006 | 12:37 PM
rgjr9852's Avatar
Passing Emissions
I just bought some Pacesetter long tubes with emissions stuff on them, and I wanted the race version long tube, I heard your car will run a lot better with all of them out. but I am worried about passing emissions. If i get my computer reprogrammed so i wont throw codes will they still be able to see that I dont have any emissions on? I have to go to emissions in June and i am throwing a code because my cats are bad, but I was just going to take them off anyways.
Did anyone take off all of their emmissions and reprogrammer thier computer and pass?
Old Dec 1, 2006 | 01:21 PM
87lt1rx7's Avatar
where are you located? generally the emissions on headers is rather important. without the header fittings for emmissions you will most likely not pass visual
Old Dec 1, 2006 | 01:44 PM
rgjr9852's Avatar
i have OBD 2 so they just plug right in, not even look at anything else
Old Dec 1, 2006 | 02:17 PM
87lt1rx7's Avatar
as far as i know there is always a visual part and a tailpipe part. it does depend on where you are though. i am in california, so they pretty much strip search me for modifications at the test only stations
Old Dec 1, 2006 | 02:52 PM
2000GTP's Avatar
Whatever you heard about a car running better without emissions equipment is incorrect. The emissions does not effect the performance of your car. If you have all of the emissions equipment removed and the codes tuned out of your PCM, you still run the risk of not passing due to too many "not ready" statuses present in the PCM.
David Dempsey
Mar 12, 2016 12:42 AM
sleeperZ96BT
Sep 9, 2015 08:28 AM
Steve69SS396
Track Kill Stories
Aug 17, 2015 08:48 PM
sherwinZ28
11
Aug 15, 2015 05:38 PM
Cam's maro
Aug 11, 2015 07:45 AM
