Painting valve covers
Old Mar 5, 2008 | 10:14 AM
Limitedr1's Avatar
I am trying to finish up the rebuild of my sons new motor(1995 Z28). But the valve covers had so much build up inside that wouldn't come out in the parts washer that I completely sandblasted them to bare metal. I wasn't thinking about them being steel and rusting on the inside. So my question is what to use to seal or paint the inside with. Anyone had any luck with this?
Old Mar 5, 2008 | 01:34 PM
Z28SORR's Avatar
Not necessary to paint the inside. The oil will protect the steel.
Old Mar 5, 2008 | 01:45 PM
dangalla's Avatar
yup, and be carefull what you clean them with if you only paint them, the paint wiped right off of mine with some break cleaner. your best bet would be to powdercoat them
Old Mar 5, 2008 | 03:06 PM
Limitedr1's Avatar
Thanks. I was thinking the oil should help, but I've seen some with rust before and just wanted to be proactive since it is a complete rebuild. And yep break cleaner will take off most anything. I will clear coat the ceramic paint so it will clean easy and prevent stuff from soaking into the paint.
Old Mar 5, 2008 | 03:10 PM
Tricked-Out-Toy's Avatar
DO NOT PAINT!!!!! The paint can flake off and clog oil ports. inside the engine there isnt any reason to "protect" any of the uncoated metal. like the guys said above, the oil is portectant enough.
HectorM52
Jul 30, 2017 11:46 AM
nikolt1
Feb 27, 2015 09:10 PM
Jazsun
Dec 29, 2014 12:14 PM
ModdedNerd
Dec 14, 2014 10:28 AM
