paging Brent/Injuneer/Shbox/experts: hesitation off idle
Old Apr 8, 2007 | 10:04 AM
foxbat's Avatar
ok, so the past few months i've noticed the following issues:
1) when warmed up i sometimes get a slight stumble if i drive off slowly in 1st gear, when the rpms reach up around 2000 it's smooth. no high rpm issues at all (hot or cold)
2) if i'm on the highway driving say 60-65 and in 6th gear, rpms are about 1500, if i hit the gas to accelerate slowly around traffic or something or up an incline, same thing - stumble appears. downshift to 5th rpms climb to >2000 no problems, and will pull smooth into high rpms.
any ideas? was tuned up with full a/c delco factory plugs/wires etc in 2001 at 65k miles. car only has 75k now.
seems to be more present when the motor has warmed up, and if i have the a/c on.
thank in advance.
Old Apr 8, 2007 | 10:07 AM
wrd1972's Avatar
I had this. It was bad plug wires and especially the coil wire.
Replaced them and the hesitation was gone.
Worn or slightly fouled plugs can do this too, might want to also replace the O2's.
Try some performance low resistance wires like MSD super conductors.
Old Apr 8, 2007 | 10:13 AM
foxbat's Avatar
hmmmm....interesting. i actually considered this but, the wires only have 10k miles on them. granted they are 6 yrs old, but the car is only driven once or twice a week. shouldn't a/c delco wires be good for >60k miles?
Old Apr 8, 2007 | 10:16 AM
mdacton's Avatar
nope.....get new wires
When you page the experts the first thing they want is a datalog......
Old Apr 8, 2007 | 10:22 AM
Monitor the TPS to see if the reaction to the throttle opening is linear.
Old Apr 8, 2007 | 10:54 AM
transAMdriv3r's Avatar
what plug wires are you guys using..are the factory delco plugs wires good or go for something better. what would you suggest?
i had some cheapo ones on and they were okay but its time to change them.
Old Apr 8, 2007 | 11:02 AM
mattbailey's Avatar
I use Taylor Spiro Pro wires. You can get them for around $40 and I've never had a problem.
Old Apr 8, 2007 | 11:26 AM
engineermike's Avatar
I've been having a tip-in lean hesitation for years now. It's not the plugs, wires, or any other ignition component. The A/F ratio pegs high when I tip-in the throttle. No one knows how to access the accelerator enrichment in the '94/'95 computers. I'm running 84 lb/hr injectors and the Acceleronics impedence converter.
Suggestions?
Old Apr 8, 2007 | 11:34 AM
PLEASE do not page specific people in the "topic". If you need to contact someone, me included, PLEASE use a PM. The tech forums are not for paging people. When I see my name called out, I ignore the post.
I'm going to start taking a hard line on this is the future, and lock/delete "pages" in the tech forums.
Old Apr 8, 2007 | 11:47 AM
foxbat's Avatar
apologies....was not aware of this rule.
Old Apr 8, 2007 | 11:51 AM
foxbat's Avatar
shoebox, can you eleborate on this a bit?
i only experience this problem when i'm driving the car/under load. if sitting in the driveway and i rev it - no problems, hot or cold.
thanks.
Old Apr 8, 2007 | 01:44 PM
thanks.
I'm just saying watch the TPS reading with a scanner while you slowy press down on the gas pedal to see if the readings go up with no jumps or bumps. The engine does not even have to be running to do this, just key on.
Old Apr 8, 2007 | 09:15 PM
foxbat's Avatar
thanks for the feedback - unfortunately i don't have access to a scanner, so might have to have a shop do that test.
Old Apr 8, 2007 | 09:35 PM
LiENUS's Avatar
A digital multimeter is enough to test it.
Nellsw88
May 27, 2015 10:27 PM
Nellsw88
May 26, 2015 05:55 AM
bfmv13trivium
Jan 14, 2015 09:57 AM
IRABuss
Sep 7, 2011 09:08 PM
