Pacesetter LT's & Passenger side floor problem.
Old Feb 3, 2005 | 01:12 AM
Don't Look Back's Avatar
Been working on putting in the Pacesetter LT's. The drivers side went in and was tightened down in about 20 minutes, but for 3 hours, my cousin and I have been unable to bolt the passenger side in. It seems that the header is against the heat shield, not allowing us to get in the additional 1/4" up in order to bolt it in. Anyone else run into this? What did you do?
Old Feb 3, 2005 | 07:38 AM
#7's Avatar
Re: Pacesetter LT's & Passenger side floor problem.
Yes this was the case for me too. I took the heat shield off at that location. Reformed some other shields out of it to protect the brake and fuel lines on the driverside in 2 areas.
T.
Old Feb 3, 2005 | 10:15 AM
FryedClutch's Avatar
usuall in tool kits you get this special tool called a hammer LOL
but seriously thats all i did was beat the heatshield outta the way until the headers fit nice but i was too lazy to take it off and all that HARD STUFF
good luck
Old Feb 3, 2005 | 04:06 PM
Thanks guys. The original idea was the hammer, but I ended up taking the head shield off, and using the small piece of it as a heat shield for the starter wires, engine ground wires. Header went in nice and smooth after the heat shield was gone.
Noct
May 26, 2016 10:26 AM
camaro98_speed
Apr 22, 2015 11:26 AM
alex5366
Feb 17, 2015 10:43 PM
