Pacesetter LT's installed..might have clearance issue
Old Jun 16, 2004 | 07:39 PM
Yby4n95Z's Avatar
It seems my drivers side pacesetter long tube at the very end, under the car looks like it is blocked from going straight back by part of the actual body. Kind of hard to explain. Basically there would be no way I can run a pipe straight back to the rear because the underbody hangs down to low. Does anyone know what I'm talking about or do I need to host a pic?
I'll be installing true duals and just want to make sure it will fit ok.
Adam
Old Jun 16, 2004 | 07:59 PM
wes95_z28's Avatar
where do you get pacesetter long tubes?
all my friends say jegs but i can never find them
Old Jun 16, 2004 | 08:23 PM
94 CAMRO Z28's Avatar
I had the same issue but when I went with the true duals, you can angle that pipe a little bit to clear, but then you loose ground clearance. I had clearance issues and the car was to loud with bullets so I just took it all of and put the Pacesetter Y pipe and the hooker catback on. The Y pipe from them has a crushed area in it to give you more clearance from the frame rail. Wes_95...I bought mine from www.redlineperformanceengineering.com
Aaron
Old Jun 16, 2004 | 08:32 PM
Yby4n95Z's Avatar
Hey Arron which way is it angled? Down?
Adam
Old Jun 16, 2004 | 08:40 PM
Well when I had the duals, the pipe that went from that header tube to the X was angled down a little bit just to give it a little more clearance, even then it was close, especially to the fuel/brake lines. It worked but clearance wasn't the best. Im much happier with the setup now that I went to the Y pipe and catback instead.
Aaron
camaro98_speed
Wheels and Tires
Mar 17, 2015 07:36 AM
'01BlackZ
Sep 3, 2002 09:53 PM
JasonD
Aug 27, 2002 10:57 AM
cryptopsy
Aug 14, 2002 05:44 PM
WantanLS1
Aug 5, 2002 02:45 PM
