P0507 Idle Control System RPM Higher Fixed ???
Old Dec 4, 2006 | 11:01 AM
cleangene's Avatar
i don't know why it cleared up after i did the following, i drilled the holes out on the TPS so as to move in any direction, will i turned back counterclock wise and restarted the car, drove awhile the code still there and idle a little rough, i turned the idle screw up a little to smooth out the ide, still had code. ok i took the TB off and removed the IAC and cleaned again, i took some 300grit wet/dry black sand paper , a very small piece , with my little finger i was able to get the paper into the IAC hole and turned it around and around, making the seat smooth which it was not, blowed out with air and carb cleaned, reset the IAC again and put back in, did the reset by starting the car with throttle part open then removed my foot from pedal counter 5 sec, shut off for 10 sec restarted, the idle was smoother, drove for a while still code, the last thing i did was to loosen the TPS again and only turned a little clock wise then tighten back down, started the car, the code left and has not come back on, good idle, runs good, go figure, it don't smake sense, but it worked.
Old Dec 4, 2006 | 11:23 AM
Did you check the TPS voltage or scan the IAC counts at any time during what you described?
Old Dec 4, 2006 | 01:30 PM
cleangene's Avatar
good question, i took it to a local repair who quote does gm repairs and they said it checked out find right after i installed new TPS, IAC, but i have not taken the car back to them now that it's fix to check again, i think they just took my money.
DirtyDaveW
Dec 1, 2016 05:37 PM
grgguy
17
Feb 23, 2015 07:57 PM
Fatdog2
Feb 13, 2015 08:19 PM
edman
Jan 25, 2015 02:41 PM
squarehead
Jan 15, 2015 07:02 PM
