Estimated crank horsepower with these mods?
Old Oct 12, 2006 | 10:46 PM
Camarocracy's Avatar
How much horsepower do you think I would make at the motor with these mods? Borla catback, Moroso CAI, 1LE elbow, air foil, tb-bypass, CC305 cam, 1.6 RR with supporting parts [pushrods, springs ect], LT4 timing chain, electric water pump, Mac/RKSport/SLP/AZ&M mid-tube headers with high-flow cat, 52mm throttle body, and possibly a Delteq ignition system. With a dynotune?
And what if I swapped on a single-plane intake manifold set-up?
Old Oct 12, 2006 | 10:59 PM
MeanGreen97Z's Avatar
Re: Estimated crank horsepower with these mods?
On stock heads with a good tune I would assume you could hit over 350rwhp.
Old Oct 12, 2006 | 11:06 PM
chrism400's Avatar
Maybe with an M6.
Old Oct 13, 2006 | 03:30 PM
I thought a single-plain would give more horsepower?
Old Oct 13, 2006 | 03:41 PM
93redBirdMan's Avatar
Yea I'd say 425 at the motor would be about right with an m6...
Old Oct 13, 2006 | 04:27 PM
Just wondering, what does an M6 have to do with crank horsepower?
Old Oct 13, 2006 | 05:15 PM
I guess nothing actually. Guess I'm just used to thinkin in terms of rwhp...
Old Oct 13, 2006 | 05:18 PM
425fwhp is really about as close to ballpark as you can get with a guess. This is assuming everything else work perfect. I dont doubt 350rwhp with an A4.
Old Oct 15, 2006 | 04:41 PM
Bersaglieri's Avatar
Everything I know about HP anymore is rated at the wheels since most people dont report engine dyno gains. Most think rear wheel power is what matter since thats a better estimate of how the car will perform, even though I'd say track times are the best indicator. I'd say 330-340rwhp depending on tranny, which I cant remember which you have. But you'd also have to take into account what converter or clutch your using, what gears you plan on matching with that cam, and suspension/tires to put the power to use. I for one can tell you that with just bolt on's, suspension, and converter, 315/35/17's cant handle the power on the street.
What are you goals for your setup, is it just a crank horsepower goal, rwhp, track time, 12 second car, or just beating someone you know? I only ask to better assess your situation.
-Dustin-
Old Dec 3, 2006 | 11:38 PM
Wow, I completely forgot about this post
Car is an A4 with 2.73 gears, at the moment anyway. Planning on upgrading to 3.73.
My goal is to get into the 12s on pump gas and street tires.
Suspension is listed in my sig.
So at least 400hp at the motor with a 305 cam. Sounds good to me.
Old Dec 4, 2006 | 08:00 AM
CamaroRacing12's Avatar
seems like we have the same goals
Old Dec 4, 2006 | 11:03 AM
You can get 9's on pump gas if you wanted to. Fuel grade isnt really the issue. You should be able to hit 12's with that cam if you practice you launch. Street tires are going to make you 60' crappy, but with the power youll be making with the cam and trap speed you should be able to hit 12's. I'd recommend some gears and/or converter before the cam, but even without them the the car will make good power, just dont expect to be a stoplight to stoplight car. You need to ride in my car before I get the cam in so you can see what a difference 3.73's and a Vigilante make in just a bolt on car.
-Dustin-
Old Dec 4, 2006 | 12:07 PM
Sweetred95ta's Avatar
Converter, gears, and bolt-ons will get you into the 12's.
Old Dec 4, 2006 | 01:18 PM
Z-RATED94's Avatar
And a little luck. What's easy for some isn't always the same for the rest of us. And for what the single plane will cost you, you would be better off spending your money elsewhere before you would really need one.
Old Dec 4, 2006 | 02:57 PM
I didnt even see the single plane intake thing. Definately not a good investment. Put the money into gears or a converter.
-Dustin-
