P0141 code - bad o2?
Old Dec 20, 2004 | 02:09 AM
kingman109's Avatar
P0141 Heated Oxygen Sensor (HO2S) heater circuit Bank 1 Sensor 2
just scanned the car and im throwing the above code- im assuming this means my rear o2 is bad ? this correct or could it be the wiring - the o2 was replaced about 2k ago
thnx
Old Dec 20, 2004 | 11:10 AM
Re: P0141 code - bad o2?
Its either a burned out heater element in the O2 sensor, or a wiring problem in the +12V supply/ground for the heater element. If you swap the after-cat sensors side-to-side, and the problem moves with the sensor, its a sensor problem. If the problem stays on Bank 1, its a wiring/power supply problem.
Old Dec 20, 2004 | 02:22 PM
kingman109's Avatar
thnx good idea
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
ad356
Apr 11, 2015 10:30 PM
captcorvette
Mar 7, 2015 12:37 PM
91Bird305
Aug 8, 2002 12:36 AM
91Bird305
Aug 5, 2002 01:39 PM
