P0135 cause bad fuel trim on bank 2?
Old Oct 31, 2014 | 09:28 AM
Red97LT1's Avatar
Been trying to figure out why my fuel trims are so bad. I've not had a CEL until this morning. P0135. Would this cause the bad trims on bank 2 also or is it an indicationindication that the 02 sensors is bad?
I've checked leaks and found nothing.
Old Oct 31, 2014 | 10:40 AM
Re: P0135 cause bad fuel trim on bank 2?
P0135 indicates the heater circuit for the Bank 1 (left/driver) side pre-cat O2 sensor may be malfunctioning. The heater controls how fast the O2 sensor heats up and starts working. The test is only run on cold start. The code sets when the PCM does not see the sensor start working in the period of time it expects.
Could be a faulty heater element in the O2 sensor, could be faulty wiring to the heater circuit.
Do you have long tube headers?
This would obviously not affect the LTFT's on Bank 2.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
maybe2fast
Mar 16, 2015 11:59 AM
97Z28Muscle
Feb 6, 2015 10:44 PM
cmdeshon
Dec 12, 2014 10:51 PM
