air/fuel and N20 guage questions
Old Jun 16, 2005 | 04:10 PM
93camaroLT1's Avatar
I got a couple questions, the first is what all do I need to use a air/fuel gauge such as ATM-4375 (autometer ultra-lite digital guage)... Do I need the 2244 accessory kit? What about the N20 gauge, Do i just need the 4an fittings and braided hoses to run that? How much hose do I need... does it need to run all the way from the bottle to the gauge?
Old Jun 16, 2005 | 04:24 PM
mattybz28's Avatar
Re: air/fuel and N20 guage questions
Yes. You'll need a "t" fitting to run the line from the bottle -> fitting then fitting -> guage and fitting -> nitrous solonoid.
Guage will also need a power and a ground.. but that's pretty much a given.
Old Jun 16, 2005 | 05:11 PM
well that clears up everything about the nitrous gauge. What about the air/fuel gauge, what all do you need to run that, do you need the 2244 (summit) accessory kit (Sending Unit, O2 Sensor, Air/Fuel Ratio..)
Old Jun 16, 2005 | 06:17 PM
ltwonz's Avatar
No you don't need any kit. It should be 3 wires power, ground, and one you splice into an o2 sensor.
Old Jun 17, 2005 | 06:56 PM
So can I just run a silicone hose for the N20 guage, or does it have to be a braided hose?
Old Jun 18, 2005 | 05:09 PM
You must use a hose with at least an 1,800psi burst strength. Given the fact that it ends up inside the passenger compartment, I wouldn't use anything less that high pressure braided S/S.
Alos, be sure to put the special flow restriction fitting that comes with the gauge in the line at the point where you take the connection off the main nitrous line. The fitting prevents a huge cloud of opaque nitrous (actually, humidity condensed by the expanding liquid nitrous) from filling the passenger compartment in the event the gauge or the line breaks.
Old Jun 19, 2005 | 02:10 PM
arnie's Avatar
Is this using a NB O2 sensor as a means of monitoring the oxygen content of the exhaust?
Old Jun 19, 2005 | 02:36 PM
justnrt's Avatar
it uses your o2 sensor and shows the voltage that it is producing, showing if your running rich or lean.
Old Jun 19, 2005 | 03:29 PM
arnie's Avatar
If that is the case, I find it a bit disconcerting that the original post used N2O gage (implying use of N2O) and a NB sensor (to monitor) in the same sentence. In addition to above, I also consider that scarey.
Old Jun 19, 2005 | 05:20 PM
??? y is using a air/fuel gauge to monitor rich/lean conditions scary?
Old Jun 19, 2005 | 06:21 PM
arnie's Avatar
It's not that using an A/F monitoring device is scary, as I would recommend using a quality unit to complement a power adder. It is using/expecting a cheap/unreliable 'switch' to undertake the responsibility of providing accurate numbers. As far as accurate numbers are concerned, the NB sensor is basically useless. If anyone is serious about getting reasonably accurate data, they better be willing to foot the bill.
Old Jun 20, 2005 | 01:27 AM
1racerdude's Avatar
The one ya will need to do it right and log the results cost over $500.00.Then ya need a laptop to download the log and read it. Just one of those light show guage will get ya a blown motor.
If ya use the recommended pills and pull 2* of timing for every 50HP ya don't need a monitoring device that ya can't read on a strip pass.Ya better be watching the center line!!!!!!!
Old Jun 21, 2005 | 02:07 PM
i wasnt planning on tuning the car with a air/fuel gauge, just was going to try and monitor detonation after the car is tuned (to make sure there is none) with the air/fuel gauge... Well that was the plan until I realized how useless these things are
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Magenta_Hearts
Mar 22, 2015 03:36 PM
Jul 4, 2005 05:00 PM
T/A lt1
Oct 10, 2002 03:14 PM
