overheating problem
overheating problem
I have a 1996 cmaro lt1 and i have been having overheating problems with my car. I have changed the radiator, water pump,cap,thermostat, i bled out the air,and i checked the fans. When i look in the radiator it does not look like the water is circulating. It over heats very quickly and i have no heat. There is nothing leaking inside the car. I also do not smell antifreeze in the car. I am so frustrated i just want my car back. Help please
What is it with overheating camaro's? Mine gets rather hot also. There is some kind of valve off the water pump that was leaking on mine. I thought I fixed the overheating problem by fixing that leak but nope still gets hot in town. If I where you man I would put a pressure tester on your car to see if you have any leaks first. Then you can feel the heater hoses if its plugged one will be hot and the other will be cold. Big difference. Hope this helps.
warmeck
Apr 16, 2015 05:50 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
