Overheating Problem?
Old Feb 23, 2007 | 02:39 AM
JamaroZ's Avatar
Well this is my first post in this section! I have a 96 Z28. One of the problems that I am having with it is an overheating problem. Everytime I get in some traffic or drive it a few places during the day I start to overheat! It is the worst when I get stuck in traffic, it goes nuts! It has an electric water pump and I am wondering if something might be up with that or maybe a new thermastat? But it does not do it when I drive it at night or am not in traffic! It will be in the shop next week. I was just hoping to get some suggestions on what it could be. So hopefully by the end of next week it will be a cool running freshly dyno tuned Z!
Old Feb 23, 2007 | 02:41 AM
SS RRR's Avatar
Do you know if your radiator fans are working?
Old Feb 23, 2007 | 09:29 AM
OBE1 95Z28's Avatar
Proper ratio of coolant to water?
Old Feb 23, 2007 | 09:39 AM
Give more details about temperature. It's normal for a car with electric fans to heat up when you stop.
Old Feb 23, 2007 | 11:51 AM
'94 Bad A Z28's Avatar
You have an electric water pump so the first thing you should do would be to check the fuse for your water pump. There is a very good chance that is what the problem is and it would be the cheapest fix.
liamcg97
Nov 25, 2019 05:55 PM
AlaskaZ28
Apr 17, 2015 08:54 AM
warmeck
Apr 16, 2015 05:50 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
