Overheating problem
Old Aug 1, 2005 | 10:38 PM
ChuCk_Z28's Avatar
Overheating problem
Hello guys, I'm new here but been researching at your site for a while now. Lotta helpful stuff.
I searched for such problem but couldn't find an exact match to the one I'm having.
I've got a 95 Z28 which overheats because fans don't turn on. Now if I turn my A/C on, both fans will turn on but they will be weak, so I decided to take a look myself at the fan wiring and after messing with it (checked volts and if the cables were properly connected) I noticed that by only leaving the passenger side fan hooked, it'd turn on at full power when switching the A/C on. I checked all the other stuff, water pump, coolant, relays, sensors.. and everything seems to be fine, could the fan gone bad? wiring maybe? Thanks.
Old Aug 1, 2005 | 10:42 PM
phinger23's Avatar
Re: Overheating problem
try jumping the fan relays. if they run really strong, then the fan motors are good. if they are weak, replace them.
Old Aug 1, 2005 | 10:46 PM
slowpoke96z28's Avatar
maybe high speed relay is bad? with the multimeter, also check to see which relay the the PCM is commanding ON and then swap the other relay out for another one and see if it works
liamcg97
Nov 25, 2019 05:55 PM
AlaskaZ28
Apr 17, 2015 08:54 AM
warmeck
Apr 16, 2015 05:50 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
