overheating problem
Old Mar 24, 2005 | 12:09 AM
tony_mid's Avatar
overheating problem
I own a '96 z28 camaro and everytime my car is idleing a lot it will start to overheat my car has an ss ram air hood with functional air box and I don't if it needs the air from the outside to cool the engine or why its doing that or if its normal any help you can give me plz post
Old Mar 24, 2005 | 12:30 AM
25thBird's Avatar
Re: overheating problem
Have you removed or replaced anything recently? Anything that may seem like it makes no difference may be the reason.
Old Mar 24, 2005 | 12:33 AM
DrivinSidewayz's Avatar
make sure your fans are turning on. check up under your car infront of the radiator and clear out any debris if its there. if your fans are turning on, try holding your motor at some RPMs... maybe you have a coolant passage block somewhere and at idle your waterpump isnt flowing enough.
Old Mar 24, 2005 | 01:31 AM
ManicHaze's Avatar
could also be you have air in the coolant hoses. When is the last time you had a flush and fill? Are you running a 160 thermostat?
also, id look into getting some Red Line Oil "Water Wetter" that stuff really helps, I know from experience with it in my car as well as my computer's watercooling setup.
Old Mar 24, 2005 | 06:45 AM
teke184's Avatar
first thought would be the mentioned malfunctioning fans, second would be a clogged radiator, third would be bad wp.
i've you have done anything coolant related recently...the air in the system would probably top that list instead.
Old Mar 24, 2005 | 06:58 AM
disco192's Avatar
Are you getting any SES codes? Check all your fuses. Most of the time overheating is a fuse or ECT problem.
liamcg97
Nov 25, 2019 05:55 PM
AlaskaZ28
Apr 17, 2015 08:54 AM
warmeck
Apr 16, 2015 05:50 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
