Need Help
Old Mar 24, 2005 | 06:27 AM
redvette93's Avatar
Need Help
I bought a CSI water pump off of ebay & it has no directions. Does anyone have a wiring diagram or directions for one of these??
I have 4 wires off the motor red, orange (with fuse), black, & blue.
Thanks, Jim
Old Mar 24, 2005 | 06:43 AM
disco192's Avatar
Re: Need Help
Wire a relay off the ignition fuse on your distribution block. If you dont run a relay, then it will fry something, most likely the ignition.
So basically,
1: Buy a relay
2: Run a wire from the ignition fuse to the 85 terminal on the relay
3: Ground the 86 terminal on the relay
4: Run a 25A fused power wire from the battery to the 30 terminal on the relay
5: Run a wire from the WP power wire to the 87 terminal on the relay
6: Ground the WP
Thats how to wire it. Install.. remove pump, clearance housing w/ grinder (if needed), put on gaskets and RTV, screw on WP, wire it up.
Old Mar 24, 2005 | 07:04 AM
30696bird's Avatar
Re: Need Help
Here is a pic of how I wired mine....Pic is easier to explain AND understand.
http://img.photobucket.com/albums/v6...0/100_0063.jpg
http://img.photobucket.com/albums/v6...0/100_0062.jpg
http://img.photobucket.com/albums/v6...0/100_0064.jpg
Hope this helps. And yes my engine is a dirty **** right now . I have not hid the wires though I am about to right now, I just never got around to it.
