Over reved the MSD Opti???
Old Apr 24, 2007 | 09:50 PM
dannyum89's Avatar
I finished installing my new Golen 396 longblock 2 weeks ago. I used my MSD opti from my old engine and has ran fine until yesterday. I was kinda racing a Cobra and found that this engine likes to rev past my 7K tach. Everything was fine until the tach suddenly dropped to zero with the engine still running. Next morning tried to fire the car up and it took a few tries to get it to start, still no tach. Now tonight the thing completely died on me. I have no spark, I changed the coil and ignition module. Still no spark, I have power going to the coil and have power going to the opti but still no spark, no blown fuses. Did I fry the opti reving it too high? Im baffled here. I have a LT1 in my S10 and rev the crap out of it all the time and this has never happened.
Old Apr 24, 2007 | 09:57 PM
reamo04's Avatar
wow, that sucks
on another note - how did she run? and did u at least beat the slowbra?
Old Apr 24, 2007 | 10:02 PM
dannyum89's Avatar
LOL! I was beating the hell outa him. I was actually letting him pull on me just so I could catch up and pass him. The power that engine makes is rediculous!
Old Apr 24, 2007 | 10:06 PM
reamo04's Avatar
well, thats whats important
as far as the opti, im not sure, ive never had to replace one yet *knock on wood* and have never looked at one off a motor yet
Old Apr 24, 2007 | 10:44 PM
dannyum89's Avatar
Right now I wish that never happened. I need to get my car back on the road. I need help before I dish out money for a new opti.
Old Apr 24, 2007 | 10:55 PM
seawolf06's Avatar
If the tach dropped to zero with the engine still running, then I don't think it's the opti. Do you have the tach running to the pcm or the 6AL or where? Sounds more like an ignition problem to me.
Old Apr 24, 2007 | 11:01 PM
dannyum89's Avatar
The tach is still running to the PCM. The car still doesnt start even if I remove the 6AL. I really hope its not the PCM. I just sent 3 PCM's to Bryan at PCM for less because I didnt need them anymore.
Old Apr 24, 2007 | 11:08 PM
seawolf06's Avatar
I know the stock pcm doesn't like going much over 7k. Did you try disconnecting the battery for 10-20 min and then reconnect and try again?
Old Apr 24, 2007 | 11:16 PM
dannyum89's Avatar
No I havent tried that. I did get the PCM tuned by PCM 4 less for that engine but im not sure if that makes a difference on the overeving part.
Old Apr 24, 2007 | 11:29 PM
seawolf06's Avatar
No, the pcm only accepts tables up to 7200 I think. Not sure.
Old Apr 25, 2007 | 02:41 AM
KWIK WS6's Avatar
From: Southern California, where do YOU live mutha****a?
thought the stock pcm shut down at 7k.
Old Apr 25, 2007 | 05:09 AM
rskrause's Avatar
Moderator
The PCM won't run past 7,000rpm. It has nothing to do with the Opti.
Rich
Old Apr 25, 2007 | 10:44 AM
Heatmaker's Avatar
Advanced Member
wow
Old Apr 25, 2007 | 05:00 PM
dannyum89's Avatar
Well guys im going to try putting my factory PCM in the car just to see if it starts. I know I can't leave it in there cause the car will run like crap but if the car starts it should rule out any other problems. Hopefully
Old Apr 25, 2007 | 10:33 PM
dannyum89's Avatar
Bad news. I tried 2 different PCM's, my factory one and my buddies 383 Madz28 PCM. The car eventualy starts with my 396 PCM but takes about 3 or 4 constant tries. When it does start the car wont idle for crap until it gets to operating temp. The tach doesn't work with either of the 3 PCM's. One question I have. Where does the PCM get its tach signal from? If I can trace that, im sure I will solve this whole problem.
