Over the axle pipe
Old Jul 25, 2006 | 07:54 PM
urbaNHunter44's Avatar
Over the axle pipe
I'm going with a powerstick right off of my 3" y-pipe, and need a 3" mandrel bent pipe to go over the axle, from there I'll custom make my own exits. I was thinking this pipe would work:
http://store.summitracing.com/partde...D43248&FROM=MG
It's for a thirdgen, but it should be able to be adapted easily enough.
Does anyone know of a fourth gen specific pipe?
Old Jul 26, 2006 | 12:27 AM
1racerdude's Avatar
Re: Over the axle pipe
http://img80.imageshack.us/img80/509...stem0011ke.jpg
http://img153.imageshack.us/img153/2...stem0030wa.jpg
This is the one I built from a pile of bends.
That pipe from Summet looks close but will probably will need fitting.
If there had been a 4" pipe already made up I would have bought it.
MODERATOR NOTE: Let's just post the links, the photos are too large and make it difficult to read the text in all the posts.
Old Jul 26, 2006 | 02:16 AM
What bends did you use exactly? that looks good
Old Jul 26, 2006 | 02:30 AM
1racerdude's Avatar
I just bought some 90/45/60* short bends(6"on either side of the bend) and cut the angles right to fit and welded it up. I also bought some 4" exhaust tubing. The merge was also purchased. There is only 1 weld joint per section and I made the mounting brackets and went to the Camaro salvage yard and got some more rubber hangers and mounted them where they needed to go to support the mass.
This was NOT a 15 minute job but I didn't work on it every day either. Lot of work cutting and fitting to make it neat.
http://img90.imageshack.us/img90/217...stem0025lw.jpg
Here is the "Y" pipe and merge. Its 2=3-1/2" to 4" out the back.Bought the muffler too.
Ya don't get this kind of work from a muffler shop.
Thanks for the complement.
Old Jul 26, 2006 | 10:06 AM
asudecat's Avatar
Thats awesome!!!!
What kind of coating did you put on it?
Old Jul 26, 2006 | 10:08 AM
1racerdude's Avatar
VHT header paint.
Old Jul 26, 2006 | 10:15 AM
asudecat's Avatar
Awesome, I may try that as well.
Will it last?
Old Jul 26, 2006 | 10:19 AM
1racerdude's Avatar
It should it's 1300 degree paint. Don't know 'bout rocks and that stuff though.
If yours is new ya will have to sand it good for it to stick.
Old Jul 26, 2006 | 10:21 AM
Sweetred95ta's Avatar
I had VHT header paint last for a while, then it starting flaking off. I had it on my headers though.
Old Jul 26, 2006 | 10:22 AM
"White Knight"'s Avatar
Awesome work Racerdude
Old Jul 26, 2006 | 10:30 AM
1racerdude's Avatar
Old Jul 26, 2006 | 10:31 AM
3DFORMULA's Avatar
beautiful job man!
Old Jul 26, 2006 | 10:34 AM
1racerdude's Avatar
The metal HAS to be clean and rough. We sanded and metal prepped this set up.
Old Jul 26, 2006 | 10:36 AM
1racerdude's Avatar
The metal HAS to be clean and rough. We sanded this with 80 grit and metal prepped it.
2QUIK6
Sep 17, 2016 02:31 PM
surreybrad
Aug 10, 2015 09:34 AM
Devinfoote87
Jul 30, 2015 09:54 AM
Jlo
Jul 29, 2015 03:52 PM
realistyc
Jul 28, 2015 07:32 PM
