Oil Dipstick Install Problems
Old Jul 26, 2006 | 09:07 AM
"White Knight"'s Avatar
Angry Oil Dipstick Install Problems
Well I can't seem to get my oil dipstick back in all the way for some reason. It goes almost all the way down, just not all the way. It is about a 1/4" to 1/2" out of the block. It feels like it is hitting something in my oil pan. It goes really smooth all the way down to that point and then I can hear it like tap and stops dead. I have pried and pulled and all I can come up with is that it must be hitting something in my pan. Any ideas what it is hitting or how I can get this stupid thing in. I have fought with it for two different days now and am getting frustrated.
Old Jul 26, 2006 | 09:10 AM
Dave88LX's Avatar
Re: Oil Dipstick Install Problems
Sounds stupid, but is there any crap/dirt in the oil pan hole?
Did you try twisting back/forth?
I had the same problem on my Mustang...now I haven't had a dipstick or tube on there for 4 years. Probably not good...but...eh.
sleeperMULLET's Avatar
is it a stock pan?
Old Jul 26, 2006 | 09:14 AM
2QUIK6's Avatar
Try sitting the dip stick tube in the freezer for about an hour or so, this will make the metal shrink just a bit and then try to install it while its very cold, may give you just enough room to get it in. If that doesn't work, you can always trim the end off by about 1/2", hell I had to cut about 3" off mine before it went in
Old Jul 26, 2006 | 09:15 AM
Sparkz28ss's Avatar
its just a bitch to do in car
Javier97Z28's Avatar
Moderator
Originally Posted by sleeperMULLET
is it a stock pan?
++1
Old Jul 26, 2006 | 09:23 AM
sorry guys. Yea it's a stock pan
Yea i have been reading posts about sanding off the paint and freezing it like you said. I didn't even need to sand, 3-4 hours of up and down took the paint right off..lol. It just stops so hard that I think the way it is bent must be contacting something inside. I have headers of course so the tube is all bend to accomodate it, I think maybe the bend is making it hit something inside. Not sure what to do.
Maybe I will just trim the end off.
Old Jul 26, 2006 | 09:44 AM
Moderator
Trim the end off, doesn't hurt anything or modify the reading, you'll be fine!
Old Jul 26, 2006 | 09:47 AM
Are there windage trays in these pans? Does anyone have a picture of the stock pan showing the inside of it? For some odd reason I am worried about the thin stick you take the reading on going somwhere it shouldn't.
Anyone have a picture of a stock pan(inside).
Old Jul 26, 2006 | 10:05 AM
1racerdude's Avatar
Put the tube in as far as it will go and put the slim inner stick in it and see if it hits anything.
Did ya put 4 bolt mains on it?
Old Jul 26, 2006 | 10:19 AM
ah that's a good idea I will have to give that a shot. If it does hit what do i do? What would it be hitting?
Nope, no 4-bolt mains. Just out for the valve cover to come off and now won't go back in.
Old Jul 26, 2006 | 10:29 AM
1racerdude's Avatar
Probably won't hit. Just cut that 1/4 in. off if ya can't screw it around and make it go in.
Old Jul 26, 2006 | 10:56 AM
Alright Sounds good.
HectorM52
Jul 30, 2017 11:46 AM
artic94
Jan 17, 2015 11:19 AM
Queens94z28
Dec 20, 2014 09:11 PM
Jul 4, 2005 05:00 PM
GigaMp3z
Feb 20, 2003 02:57 PM
