Out of ideas
Old Jul 19, 2006 | 08:43 PM
  #46
Sweetred95ta's Avatar
Re: Out of ideas
Do you have anyway of scanning the car? Laptop and cable?
Old Jul 19, 2006 | 09:02 PM
  #47
tritonium's Avatar
Re: Out of ideas
been there, tried that with 2 different PCM's
2 different cables
Same computer
same software datamaster DA
It wont read.
Old Jul 19, 2006 | 09:25 PM
  #48
Re: Out of ideas
Test the resistance of the wire. Make sure it matches the other wires. Then, buy a vacuum gauge and test the actual vacuum.
Old Jul 24, 2006 | 11:23 PM
  #49
tritonium's Avatar
Re: Out of ideas
Took off the timing cover and checked out the mechanical aspects of the engine, and the opti position.
Checked the Coil - its good
New Opti
New ICM
New MAP
New TPS
New EVAP solenoid
New EGR solenoid
I'm going broke on probably perfectly fine sensors - since i cant scan the car it's a game.... a crappy game!
Everything is perfect.. With all the mechanical aspects.
I Just ordered new spark plug wires to rule them out. Even though they are verynew Accel 8mm wires I had crimped 2 of them between the block and the accessory bracket. I am replacing them and hopefully all these issues will just vanish
I want to thank everyone here for your help there are a lot of replies in this thread from many members, and I do truly appreciate it so THANKS!
I'll figure it out sooner or later and then it will be :hyper: AWESOME!
Old Jul 24, 2006 | 11:26 PM
  #50
Alvin@pcmforless.com's Avatar
Re: Out of ideas
2 different cables
Same computer
It wont read.
Sounds like you have a chip install error or bad PCM.
To double check you can jump the upper two right pins of the DLC and see if the SES light blinks. IF it doesn't ou have a problem with the pcm or chip.
Without a datalog your going to keep throw money at it. Its best to just figure out how to get the datalog to work at least so we can find the issue.
Old Jul 24, 2006 | 11:41 PM
  #51
LT1_383's Avatar
Re: Out of ideas
I just thought of this. You migth want to try and disconnect the computer. Find out which pins go to the diagnostic port and do a continuity test for each wire. Make sure nothing got pinched somewhere in the harness. This way you can rule out the harness as being a reason for the communication error with the computer.
Old Jul 25, 2006 | 07:16 AM
  #52
Re: Out of ideas
Even w/out Datamaster, you can check most of the sensors with a multimeter to make sure they are working correctly. Shoebox's website has everything you need. Hopefully the plug wires fix it.
Old Jul 25, 2006 | 09:09 AM
  #53
tritonium's Avatar
Re: Out of ideas
The car does enter it's diagnostic mode so I do not believe it was a chip install error, not a bad PCM . Just to clarify - The PCM is the computer the chip is installed into.
When i was converting the car there was a small black rectangular box that had a 14 or 20 pin green connector on it. The box was a big bigger than the average wallet. What is this - and could it cause all these issues?
Old Jul 25, 2006 | 09:10 AM
  #54
tritonium's Avatar
Re: Out of ideas
I will do this -
Could the wires be pinched even if the car enter diagnostic mode with the paper clip method?
Thanks .
Girrrrl
Aug 20, 2015 09:26 AM
Girrrrl
Aug 20, 2015 06:17 AM
TGGodfrey
Aug 18, 2015 06:08 PM
Devinfoote87
Parts Wanted
Aug 6, 2015 05:05 PM
asilomar244
Jul 12, 2015 05:53 AM
