Other options for Meziere/CSI pump freeze plug?
Subscribe
Nov 3, 2003 | 03:06 PM
I found a crack in the water pump on my engine... which certainly clears up the source of the rust trail down the front of the block. I should have known better than to send down a used pump (it appeared to be in very good condition, but still...) to use on my engine. The problem is that when my Meziere electric pump was installed, the freeze plug was cemented in place.
I've ordered a new pump (housing), and although I'm sure I could probably get a replacement from Meziere, is there a readily available freeze plug size that works for situations like this?
Reply
Nov 3, 2003 | 06:33 PM
It's a 1-1/8" brass freeze plug.
Reply
Nov 3, 2003 | 08:15 PM
It's a standard freeze plug you can just get one that measures the same and pound it in with a socket. I have mine out to install my CSI if you really want I can measure the opening.
Reply
Nov 3, 2003 | 08:29 PM
I ruined the freeze plug trying to put it in and did not want to run to the store so i used JB Weld...worked great and i have had know problems....
Reply
Nov 3, 2003 | 09:59 PM
I placed a penny on the inside of the pump housing, jb welded on the front and back. Holds well and only cost me 1 cent
-Shannon
Reply
Nov 5, 2003 | 04:21 PM
Quote:
Thanks!
Reply
Subscribe
