Ordered new opti
Old Feb 24, 2009 | 03:59 PM
jtarp's Avatar
Ordered new opti
Ok I ordered a new opti and I was wanting to know what seals I will need for the water pump and opti when I re-install them. Part #'s would be helpful also. Thanks.
Old Feb 24, 2009 | 04:02 PM
bowtiedad_z28's Avatar
Basically just the 2 water pump gaskets. Just go to any parts store and get them.
Old Feb 24, 2009 | 04:04 PM
ulakovic22's Avatar
If just replacing the Opti then you will only need WP gaskets. The o-rings come already installed on the shaft of the opti. If you are going to replace the opti seal in the timing cover you will obviously want to pick that up as well when you get the WP gaskets.
Old Feb 24, 2009 | 04:07 PM
jtarp's Avatar
Ok, I bought my opti from thepartsladi. So, the o-ring for the waterpump shaft should be included?
Old Feb 24, 2009 | 05:29 PM
raroz28's Avatar
It was on mine.
Old Feb 24, 2009 | 06:08 PM
jtarp's Avatar
Alright, thanks guys.
Old Feb 25, 2009 | 07:53 AM
BTC's Avatar
BTC
From: Lansing, MI via Bowling Green, KY: Dalton, GA: Nashville, TN & Atlanta, GA
If the opti & water pump drive seals in the timing cover haven't been changed in awhile, I would consider replacing both of them.
Old Feb 25, 2009 | 04:32 PM
jtarp's Avatar
I don't think they have ever been changed, but that's not say the previous owner didn't change them. Can I pick them up from a local parts store? I would order them from summit, but they are out of stock there, and I would need them by this weekend.
Old Feb 26, 2009 | 12:19 PM
BTC's Avatar
BTC
I got my seals from Jason Cromer, but I ordered a bunch of other stuff at the same time. Wherever you end up getting them, I would get extras in case you damage a seal during installation, which seems to happen quite frequently.
I think that maybe Felpro makes a seal kit, or gasket kit, that includes those seals. It might be available at places like Autozone, or Advance Auto.
Old Feb 27, 2009 | 12:06 AM
jtarp's Avatar
Alright, will do. Thank you
Sergio
Jan 27, 2016 04:27 PM
HarleyZ28
Oct 5, 2015 06:23 AM
grabbem88
Mar 18, 2015 01:25 PM
maybe2fast
Feb 5, 2015 05:14 AM
