lt1 waterpump differences??
Old Feb 26, 2009 | 02:17 PM
BrettP_95Z's Avatar
I bought a new waterpump fro my camaro a while back, i just found out that its apparently for a corvette lt1. The part numbers are only a few different and the only noticable difference is one of the extensions on the top is curved differntly, which wouldnt appear to be a problem, but one of the extensions on the bottom right is not even there? I was wondering if anyone knows what the difference between the 95 camaro waterpump and the vette one, and if i can use the new vette one i have on the ol' Z?
Old Feb 26, 2009 | 06:19 PM
Rich2279's Avatar
"The upper heater hose pipe points at a different angle and it does not have the bypass/oil cooler pipe."
http://shbox.com/1/lt1_water_pumps.jpg
Old Feb 26, 2009 | 11:07 PM
BrettP_95Z's Avatar
Thanks Rich, thats some of the info. i was lookin for! Now can anyone tell me why the oil cooler pipe was on the camaro wp, and not the vettes? ANd also since i have the vette one if it is directly applicable to my camaro, or does it have to be specific? Thanks again for responses.
Old Feb 27, 2009 | 12:28 AM
sbs's Avatar
sbs
Because there's no oil cooler to connect it to...
Old Feb 27, 2009 | 06:51 AM
If you have no oil cooler to connect, you can use the non-f-body pumps. But, the heater hose pipes might give you some problems. You would also have to cap off the port on the radiator where the oil cooler bypass hose would go.
If you want to keep headaches at a minimum, use an f-body pump.
Sergio
Jan 27, 2016 04:27 PM
InfernalVortex
Jan 17, 2015 09:35 AM
Jul 4, 2005 05:00 PM
