Opti w/o vacuum lines
Old Jan 21, 2007 | 03:55 PM
joe-96z1le's Avatar
What happens if you run an LT1 motor opti without the vacuum lines connected? Does it screw-up the opti?
Old Jan 21, 2007 | 04:29 PM
OBE1 95Z28's Avatar
The opti will die prematurely.
Old Jan 21, 2007 | 05:26 PM
You get no benefit that the vacuum lines provide.
Old Jan 21, 2007 | 06:12 PM
The vent system is there to eliminate the ozone generated by the high votage discharge in the cap and rotor. Ozone causes corrosion, and damages rubber. A fringe benefit is the elimination of any moisture that may get past the flimsy seals.
Old Jan 21, 2007 | 07:24 PM
joe-96z1le's Avatar
Thank you for the info.
Old Jan 26, 2007 | 12:18 AM
fbodyluvr's Avatar
how long will an opti last w/o the lines hooked up. I think I fried mine (see my other post) while waiting for the vacuum lines to arrive after I switched to a vented system. I am running the vacuum but having possible opti problems. Thanks!!
Old Jan 26, 2007 | 06:56 AM
It's not something that would happen right away. It would take some time.
HectorM52
Jul 30, 2017 11:46 AM
dluna333
15
Mar 13, 2015 12:30 PM
Patrick Kovack
Mar 8, 2015 09:26 AM
grgguy
17
Feb 23, 2015 07:57 PM
