need quick help...how to take the crank position plate off...
Old Aug 16, 2004 | 07:05 PM
96LT1TX's Avatar
I need help basically... I am in the middle of trying to get my car running again and I need to know how to get the crank position plate off so I can retime to timing set to dot-dot... I cannot see it at all w/ it there.
any advice helps, thanks
Old Aug 16, 2004 | 07:07 PM
96LT1TX's Avatar
Re: need quick help...how to take the crank position plate off...
anyone know another good guide to cam installs? sorry shoebox's is a 95 so he doesnt have the plate... anyone?
Old Aug 16, 2004 | 07:19 PM
You mean the reluctor for the crank position sensor? It just sits on there and you can move it if you need to. I don't see how it is causing you a problem. They all line up the same way, whether the reluctor is there or not.
Old Aug 16, 2004 | 07:21 PM
96LT1TX's Avatar
I cant really get it off.. Im afraid to tap it sideways seeing as I have already kinda taken a good chunk out of that keyhole... any easy way to get it off w/out finishing off the keyhole.
how hard is that to replace w/out taking out the crank?
thanks again shoebox
Old Aug 16, 2004 | 08:10 PM
I would think some "love taps" would make it come off, though it seems you should be able to judge where the dot is by looking at the position of the keyway.
HectorM52
Jul 30, 2017 11:46 AM
Dylan Latshaw
Mar 21, 2015 09:48 AM
VF-124
Mar 16, 2015 08:14 PM
silvermansteve
Mar 4, 2015 05:02 PM
Queens94z28
Dec 20, 2014 09:11 PM
