opti spark replacement?
Old Feb 28, 2006 | 11:41 AM
  #16
Goth z28's Avatar
Re: opti spark replacement?
Originally Posted by moparman
WHAT YEAR is your car? OBDI, OBDII?
it's a 93
Old Feb 28, 2006 | 11:58 AM
  #17
95_z28_4_Ivan's Avatar
I had similar problems with my car about 5 or so months ago, I first replace the opti-spark, but still felt pretty weak and there was a weird smell coming from the dash, idle niddle jumping back & forth. Long story short it turn out to be the ignition switch. Something to consider.
Here is a link: http://shbox.com/ignsw/ign_switch_repl.html
the actual ignition switch cost about $12
good luck.!!
Old Feb 28, 2006 | 01:22 PM
  #18
94Camaro_Z_28's Avatar
The opti itself is not to hard to replace, escpecially the 93/94. I just replaced one on a 95, and kicked myself in the *** for it after. Got the new opti for $289 from Advance Auto....price matched to Summit. Put it on, tore the old one apart, turns out it was blinded by rust. Could've fixed it. Just be sure to look into cheaper and easier things before blaming the Opti. For $1700, I'm sure they'll tell you it's the Opti everytime.
If you suspect and injector, thats a good place to start. I know that you can check them, I just don't know how.
Old Feb 28, 2006 | 02:12 PM
  #19
moparman's Avatar
The opti usually will cause the SES light to come on. Do you have any codes?
Old Feb 28, 2006 | 02:41 PM
  #20
Goth z28's Avatar
nope no codes. And everywhere i take it they seem to have a diffrent answer as to what it could be and they all make sense
Old Feb 28, 2006 | 06:21 PM
  #21
JeffK's Avatar
Man....For $1700 they should at least take you on a date, dinner and a little action afterwards.......
I replaced mine last year and it is not at all that bad. You just have to watch what you are doing.
Old Feb 28, 2006 | 06:29 PM
  #22
moparman's Avatar
Get a noid light to check the injectors. I think Autozone has them. You might also check the fuel pressure. You can get a loaner tester at Autozone. They do charge a fee to take it out, but you get it back when you return the tester.
Old Mar 4, 2006 | 12:05 PM
  #23
Goth z28's Avatar
Well i decided to try to replace the oxygen sensors first before trying anything else and the car seems to be fixed. But i could only get to the driver side one is there an easier way to get to the passenger side one then removeing the starter and y pipe? Also when i first fired the car up after only replaceing one i noticed that the car backfired and ran like crap for a bit but then started to run better and seems to be running great now. Is that normal? It is also smokeing a bit of white smoke is that just from sitting for 6 months maybe? The exhaust smells like a car exhaust but it doesn't reak of gas anymore. Thanks to all who help me on this board.
grabbem88
Mar 18, 2015 01:25 PM
ch3vyb1gbl0ck
Jan 28, 2015 04:45 PM
Iamherefornow
Jan 26, 2015 04:57 PM
brentbrowning01
Dec 3, 2014 10:36 PM
Brett 91 RS LT1
Mar 12, 2003 10:02 PM
