Opti-spark iritation
Old Apr 11, 2005 | 07:17 PM
chaser2440's Avatar
Need help finding the best place to order a delteq system to replace my opti-spark on my 96 Thanks for the help.
Old Apr 11, 2005 | 07:21 PM
EVERESTZ28's Avatar
Re: Opti-spark iritation
how can i know if my opti-spark is not working properly, I have a ignition problem but not sure about what it is.
Old Apr 11, 2005 | 07:44 PM
cas0484's Avatar
I would check plugs and wires first. If those check out then check your fuel pressue. All of those can lead to miss/backfire/loss of power "ignition related" problems. If you do narrow it down to your opti you have a few choices. First of all, check any codes you may have. If your throwing an opti code chances are your optical pickup is bad on the opti and the delteq system won't work, you'll be forced to replace the opti. If you don't have any codes and the plugs/wires check out then you might have gotten lucky and just need to replace the cap/rotor part of the opti, this is the part that usually goes out. If you need a cap/rotor you can either 1. Replace just the cap/rotor 2. Replace the entire opti 3. Convert to the delteq or LTCC system or throw a dynaspark on there. I chose option 3 with the delteq system because I replaced my entire opti 4 months ago and my cap/rotor went out on me. Since my opti is practically brand new, I knew the optical pickup was ok and decided to order the delteq system. You can order it from elitesparkplugs.com or direct from delteq themselves at delteq.com. I live in northern virginia and delteq is actually 15mins away from where I am so I picked it up locally and got to meet the guys. Very nice, very knowledgable and a great product. You won't be disappointed with delteq. Just my .02 Goodluck!
Old Apr 11, 2005 | 08:48 PM
Evilfrog's Avatar
http://www.elitesparkplugs.com/
Formula Steve
Sep 19, 2023 08:31 AM
Dizzy1
Parts Wanted
May 1, 2004 06:07 PM
Dizzy1
Apr 24, 2004 11:14 PM
LS1-Maniac
Oct 16, 2003 04:33 AM
94DROPTOPZ28
Mar 1, 2003 02:44 AM
