opti spark help
Old Feb 16, 2008 | 07:57 PM
myswt30th's Avatar
opti spark help
can I block off the 2 vac/lines from the opti
Old Feb 16, 2008 | 08:07 PM
greenmachinedriver's Avatar
it would not be recomended. why would you want to?
Old Feb 16, 2008 | 08:44 PM
BlazinREDZ28's Avatar
the vaccum lines on the opti is a vent. That is what gm did to try to improve on the non vented optispark.
Old Feb 16, 2008 | 09:14 PM
You can if you must, but it would be better to leave them operational.
Old Feb 17, 2008 | 10:17 AM
GM added the vent system when they realized the ozone generated by the high voltage spark was causing corrosion and premature failure in the UNVENTED Optis. Why undo one of the more positive changes that GM made.
One line is a filtered/MAF measured air supply line, the other is a vacuum line, with a check valve and a filter.
Old Feb 17, 2008 | 09:16 PM
97 6SPEED Z's Avatar
Unhappy
First off, (and as others have hinted at above), there are NOT two(2) vacuum lines on a vented Opti. The line from the die cast aluminum base of the vented Opti does indeed run to a vacuum source and, hence is a true vacuum line. The other line running to the Optispark cap is a vent line which supplies filtered fresh air to the cap side of the Opti.
If you want to ..... yes, technically, you can unplug and block off the one (1) true vacuum line on BOTH its Optispark and vacuum source ends, but ...... if you block off the vent line without also disconecting the vacuum line source ........ having the vacuum line still "pulling a vacuum" on the Opti WITHOUT a "vent source" ........ will cause the phenolic Optispark distributor cap to deform under normal atmospheric pressure, and cause the cap to hit the rotor underneath it.
Like everyone else asked, WHY would you even be thinking of doing this???
Old Feb 18, 2008 | 12:49 AM
On my car, the hose from the cap is the vacuum and the one from the base is the fresh air feed.
Old Feb 18, 2008 | 09:25 AM
Unhappy
I do not have my car handy to check it, and I absolutely believe that Shoebox is probably correct about the cap hose being the vacuum line and the base hose being the fresh air vent, but .............. the important thing we're trying to warn you about is NOT to block the fresh air feed while still "pulling a vacuum" on the Optispark!!! Doing this will cause the Optispark distributor cap to deform over time until it impinges upon the turning rotor beneath it. Got it?
jmadoll
Jun 10, 2015 04:41 PM
beltrunner
May 17, 2015 10:18 PM
Iamherefornow
Jan 26, 2015 04:57 PM
Brett 91 RS LT1
Mar 12, 2003 10:02 PM
DTK
Aug 14, 2002 06:14 AM
