Opti rotor in pieces...causes?
Old Aug 22, 2010 | 01:46 PM
  #16
Jameslt1TA's Avatar
Originally Posted by blown94
You know instead of capping the heater lines on the w/p you can remove the tubes from the pump and tap/plug them. This would be a better option, and safer.
Good idea, thanks. Ill have to do this. It's probably only a matter of time before this opti fails and ill have it apart again lol.
Old Aug 29, 2010 | 07:32 PM
  #17
Jameslt1TA's Avatar
Pretty sure another rotor just fell apart. Had to tow the car once again.
Old Aug 29, 2010 | 07:54 PM
  #18
brucer's Avatar
are you loc-tighting the rotor screws?
also, i was told there needs to be a restrictor/orifice of some type and also a one way check valve on the intake side of the optispark vacuum harness...
Old Aug 29, 2010 | 10:27 PM
  #19
Jameslt1TA's Avatar
Haven't tore this one apart yet, but the other two the rotor screws were still tight. It was the rest of the rotor breaking. The one on the car now has a broken vacuum port on the cap plugged with a screw and silicone. All that was hooked up for a vent was one line to the manifold with a check valve so that it could only pull vacuum on the opti.
Old Aug 29, 2010 | 10:43 PM
  #20
Think what happens when you pull a high vacuum on the Opti.... it sucks the cap inwards.
Old Aug 29, 2010 | 10:59 PM
  #21
Jameslt1TA's Avatar
Oh...that could be what did it. At idle it does pull over 10 in. of vacuum. Although I was under 5psi and half-throttle when it started backfiring and then finally died. When i put the new opti on i will make sure not to break off the vacuum port and hook the vents up properly.
I'm thinking I should probably hook up the vent for the air intake sided before the turbo right?
Old Aug 29, 2010 | 11:22 PM
  #22
When you decel, the vacuum can approach 25"Hg.
Have you checked the dowel pin length?
Old Aug 29, 2010 | 11:48 PM
  #23
Jameslt1TA's Avatar
Ya I put some chapstick in slot for the dowel pin and it didn't squish it all the way in. Didn't have any clay. That and you can see wear marks that indicate the dowel isn't going in to far.
I will take more pics this weekend when I get time to tear it apart. This was an original ac delco cap and rotor off of my ta with over 100k miles, so it could have just been because it was old.
Old Sep 5, 2010 | 11:40 PM
  #24
Jameslt1TA's Avatar
Stupid....
I replaced the opti...no start. Then the coil...no start. Decided to unhook the msd box and see if thats it. Green wire to the coil under all my electrical tape that i didn't solder was unhooked. I know I'm supposed to check all connections, but got carried away with throwing parts at it. Just sharing so my stupidity can be your gain.
On the up side it runs a lot smoother with the new coil. That and hopefully it will last with the opti now vented properly and not having a cap on it with a broken and plugged port. I have it hooked up normally with the check valve and orifice. Then the cap is hooked up to a small 3/8'' breather located in the front bumper that way it can draw nice cool air in. I don't drive the car if there is even a chance of it raining, so not worried about that.
Thanks for all the help
James
Boss002
Jan 20, 2016 12:17 PM
Xiantyl
Jul 21, 2015 05:42 AM
RUNMYTA
Jul 15, 2015 07:50 PM
asilomar244
Jul 12, 2015 05:53 AM
gonzo275rltw
Jul 11, 2015 04:19 AM
