Opti problem, cant get the balancer off need help
Old May 17, 2006 | 01:08 AM
balls51's Avatar
water pump is off, but cant get the balancer off the crank, any help, do i need a puller or what any help.
Alex
Old May 17, 2006 | 01:13 AM
Hot94Z28's Avatar
Re: Opti problem, cant get the balancer off need help
I had to use a puller some dont
Old May 17, 2006 | 07:30 AM
Its due to the heavy rust buildup. Some good penetrating oil like PB Blaster might help. Do not hammer or pry on the outside of the damper, it will damage it. If all else fails, you need a 3-jaw puller, set up to pull from the inside edges. Shoebox always has good info on most problems on his website:
http://shbox.com/1/pull_pulley.jpg
HectorM52
Jul 30, 2017 11:46 AM
grabbem88
Mar 18, 2015 01:25 PM
Newgmman
Feb 25, 2015 02:53 PM
1LEThumper
Jul 14, 2003 12:45 PM
