Opti Install Question
Old Aug 21, 2008 | 01:30 AM
lightskindwonder's Avatar
I'm just finishing up an opti replacement and when I went to put the harmonic balancer back on, I realized that I did not take note of the arrow's orientation before I removed the balancer. So, not knowing the correct orientation, is it possible to figure out how the harmonic balancer should be aligned & installed just by looking at the crank hub? Or is it even that big of a deal? If i need to do top dead center....how do i do that? will i have to remove everything that I just finished putting back on?!
Any help is greatly appreciated.
Old Aug 21, 2008 | 04:03 AM
2manyToyz's Avatar
For TDC
http://shbox.com/1/4th_gen_tech2.html#adjust_valves
i was just there a minute ago, lucky you
Old Aug 21, 2008 | 05:11 AM
If you removed only the damper, and not the hub, the damper will only bolt back on the hub one way. The three "arms" on the hub are not equally spaced. If you removed the hub, you did it the hard way. Since its a "damper" and not a "balancer", exact orientation is not critical. That's why the factory didn't bother to put a keyway in the hub.
mikey4play
Mar 15, 2015 11:45 AM
Injuneer
Dec 15, 2014 09:36 AM
pologreen97z
Dec 2, 2014 10:42 AM
GigaMp3z
Feb 20, 2003 02:57 PM
