opti install problem
Old May 3, 2005 | 05:35 PM
  #31
romoranger's Avatar
Re: opti install problem
ok, so the coil wire from the icm?
Old May 3, 2005 | 09:07 PM
  #32
Originally Posted by Hypxic1
A bad optispark will destroy plug wires real fast.
How?
Old May 3, 2005 | 11:17 PM
  #33
romoranger's Avatar
ok so i get my car started to being the limping 8 miles ride to where i was going to replace the reman. opti with a new GM one. my car lit on fire. right now all i can see from the top is no damage and the top half of my oil dip stick gone. the fire stank of spark plug wire.
i was driving when it started to smell bad and temps went up, then smoke came out from underneath the hood. i open hood and see fire underneath/on kind of the passenger side header. i douse in water. car seems fine, but it still stinks of burned plastic, i am assuming just the spark plug wire as the car was running until i shut it off. i think i might have engaged in the most horrible cam swap in history. Firebird Raceway has open track friday, and this car is going to make it onto that strip, on fire, running, or not. i have a free wednesday and thursday and am having no mercy on this thing. it will like the cam, no matter what it has to say about it.
Old May 3, 2005 | 11:42 PM
  #34
romoranger's Avatar
oh yeah, now i have a sweet excuse to change the spark plugs and wires. i am just going with checker wires, the GM ones seem to work, but should should i put in there for spark plugs?
Old May 4, 2005 | 12:17 AM
  #35
romoranger's Avatar
wow, i just went out and looked. the spark plug boots on cylinders 6 and 8 are what went on fire, the wires went with them. there is also a harness down the strut tower that got a bit hot and melted a little. i wil have to take pictures of this carnage to see if anyone recognizes anything important and/or expensive
Old May 4, 2005 | 05:38 AM
  #36
slopokrodrigez's Avatar
I need the answer to this one too!!!!!! Since the feed back section has no influence on the high voltage side and the high voltage side of the opti is only a set of contacts and a rotor. I'm very curious how this could happen.
Please explain.
Old May 4, 2005 | 07:08 AM
  #37
baron4406's Avatar
Please explain.
Ok you have a bad Opti but you think its because the plug wires are in the wrong order, so you pull off the wires then rearrange them. After 3 times you pull an end off your plug wires. Presto!
Old May 4, 2005 | 01:49 PM
  #38
romoranger's Avatar
how do ou access the plugs/wires on the rk sports/azsm marine headers? i think its physically impossible
Oncomingstorm22
Jan 22, 2015 07:15 PM
Injuneer
Dec 15, 2014 09:36 AM
GigaMp3z
Feb 20, 2003 02:57 PM
